Old 07-05-2015, 01:53 AM   #1
Skyphire
Drives: FRS
Diode Dynamic Licence plate bulbs
I just purchased 2 pairs of 194 HP3 cool white for the licence plates and the sidemarkers, but they don't work? Am I placing them in wrong somehow or is this bulb common to not work?
Skyphire is offline   Reply With Quote
Old 07-05-2015, 02:12 AM   #2
Adox
Adox's Avatar
Drives: 2014 Firestorm FR-S
"If it does not work the first time, try flipping it around in the socket, as all LEDs require the correct polarity." Right off of their website
Adox is offline   Reply With Quote
Old 07-05-2015, 02:19 AM   #3
Skyphire
Drives: FRS
Yeah I tried that.
Old 07-05-2015, 02:21 AM   #4
Adox
Adox's Avatar
Did you turn your car lights on..?
Old 07-05-2015, 02:31 AM   #5
Skyphire
Drives: FRS
Lol yes
Old 07-05-2015, 02:31 AM   #6
Skyphire
Drives: FRS
Im thinking it maybe the wire things I just watched their video gonna try it
Old 07-05-2015, 02:40 AM   #7
Adox
Adox's Avatar
I'm not familiar with the side marker bulbs, but the licence plate bulbs should work one way or the other in the socket. Maybe faulty bulbs, but the odds of two bulbs not working is probably low I would contact them to see if they can give you any tips or possibly replace them.
Old 07-05-2015, 04:09 AM   #8
BeRZed
Sometimes the metal clips/tabs that hold the bulbs become loose and cannot make contact with the LEDS. Gently squeeze the metal clips slightly towards each other with a needle nose plier. Should fix the problem.
BeRZed is offline   Reply With Quote
Old 07-05-2015, 02:55 PM   #9
Randiesel84
Drives: 2014 Whiteout Monogram 6MT
I just installed some sidemarker bulbs also. I had to adjust the metal contacts on the bulb a little, they were not making contact with the socket clips.
Randiesel84 is offline   Reply With Quote
Old 07-05-2015, 03:19 PM   #10
Skyphire
Drives: FRS
Will try that. Thanks!
Review: Diode Dynamic FRS Always-On Module N1rve Cosmetic Modification (Interior/Exterior/Lighting) 43 03-14-2016 02:35 PM
Help!! Diode Dynamic drls are melting?? Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 51 07-10-2015 10:49 AM
Complete set of Diode Dynamic LED lights from my BRZ kthrash Exterior Parts (Aero, Lighting, Etc.) 0 04-02-2015 11:53 AM
I got some diode dynamic lighting for my car!! Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 35 03-27-2015 01:58 PM
Anyone use diode dynamic fog lights with HiD? KamakazeProject Cosmetic Modification (Interior/Exterior/Lighting) 7 01-24-2014 03:41 AM
