Old 07-01-2015, 05:07 PM   #1
bizintine
bizintine's Avatar
Drives: 2013 whiteout frs
Damaged flywheel?
So I have been noticing a somewhat high pitched spinning/grinding noise. I notice it mostly when I am in 1st or second gear. I give it a little gas and as soon as I release the gas pedal I hear the noise. Its almost as if giving it gas gave the it the momentum to spin and make a grinding noise. Mind you I learned how to drive stick in this car.. so I have had my fair share of stalling out and riding the clutch before I got it down. I also hear this noise sometimes when I put the car into gear. It feels like its caught on something, then when I push hard enough it feels like I pushed something that starts the spinning/grinding noise. Could I have damaged my flywheel during the learning process of driving stick? My car is still under warranty for about 3000 more miles and I was wondering if the dealership can fix this. Any suggestions would be great thanks guys.
Also the car has been lowered, aftermarket tail lights, drop in air filter and rims. Will any of these void my warranty if I take it in like this?
bizintine is offline   Reply With Quote
Old 07-02-2015, 01:04 AM   #2
humfrz
Well, if the noise is drivetrain related, it would more likely to be a warn clutch plate or a whacked out pressure plate, rather than the flywheel.
Could be a messed up throwout bearing.
Yep, good plan, take it into the dealership for a checkup.
I doubt your car's warranty work (for this disorder) would be denied because of lowering or lights or rims or filter.
humfrz - out of popcorn
humfrz is online now   Reply With Quote
bizintine (07-02-2015)
Old 07-02-2015, 02:06 AM   #3
bizintine
bizintine's Avatar
Thanks @humfrz I'll deffinitely be taking it in then. Oh also as far as voiding my warranty work, what if I did my own oil changes.?
Old 07-02-2015, 02:44 AM   #4
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
You should be fine with your own oil change. I flushed out my radiator, did my own oil change, removed my gas tank and had it cleaned and no issues at dealer today informing them of it. If they give you cr@p, go to the next one. Ask to take techy on ride along,show them your issue, then have them drive it, speak to them w/o office/window service personnel and you'll see they more patient, and might even thank you for giving them a chance to get some fresh air. This way you get more direct help.
Packofcrows is offline   Reply With Quote
The Following User Says Thank You to Packofcrows For This Useful Post:
Old 07-02-2015, 02:55 AM   #5
humfrz
You should be OK. I'd suggest you have a little notebook with noted mileage, date(s) and how much of, and what kind of, oil & filter you used, just in case they should ask you.
I hope your car's problem is not serious .....
humfrz
Old 07-02-2015, 03:12 AM   #6
bizintine
bizintine's Avatar
Love the idea of taking a tech along with me. The only problem is I only hear the noise CLEARLY at night when there's no outside noise. And also the issue with having to shove it into gear only happens sometimes. Don't want to look like the idiot that claims all these issues with my car then when I show up there's nothing wrong hahah.
Old 07-02-2015, 03:14 AM   #7
bizintine
bizintine's Avatar
humfrz
Good thing I already have that notebook handy
Old 07-02-2015, 03:31 AM   #8
Packofcrows
Do what I did:
-Recorded on Ipod to capture specific issues
-Recorded on GoPro 24/7 whenever I was driving
-Kept journal of issues with time, date, small explanation of issue, and what I was doing at the moment the issue rose up. Also, tried to pinpoint issue note added.
If noise is an issue, take techy to where it is quiet. I took mine 20min away from dealer to back-roads so he could hear clutch.
Old 07-02-2015, 03:48 AM   #9
bizintine
bizintine's Avatar
Do what I did:
Hmm well I don't have an ipod nor a go pro. Plus I doubt I would be able to get a good audio recording of the sound. I'll try driving around tonight and see if there's a pattern of what I do that causes the sound/gear seeming to get jammed. Thanks for your suggestions they are much appreciated
Old 07-02-2015, 03:50 AM   #10
Packofcrows
lol no problem. I meant for you to just get some type of footage. Otherwise, depending on your tech, they might ignore you lol
Old 07-02-2015, 04:12 AM   #11
bizintine
bizintine's Avatar
Yeah your right I mean it wouldn't hurt. Maybe I can find a friend with a good camera to get an in car shot of the noise
Old 07-17-2015, 04:10 PM   #12
bizintine
bizintine's Avatar
So I took her into the dealer the other day. Bad news is I need a new tranny.. Good news is its covered under warranty!! Waiting for it to get shipped to my dealer
Old 07-17-2015, 11:49 PM   #13
humfrz
Well, that's good they got it sorted out and will make it good.....
How many miles on your car .. ??
Have you tracked it .... ??
Just curious.
humfrz
Old 07-18-2015, 07:30 AM   #14
bizintine
bizintine's Avatar
Just curious.
humfrz
33k never tracked it. I've always wanted to though.. I just dont know where to start
The Following User Says Thank You to bizintine For This Useful Post:
humfrz (07-18-2015)
Damaged my apr splitter Rocket.BRZ Cosmetic Modification (Interior/Exterior/Lighting) 23 07-18-2018 10:16 PM
Damaged tire frs_94 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-31-2015 01:09 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Wind damaged BRZ's thermobox Scion FR-S / Toyota 86 GT86 General Forum 2 08-24-2012 04:23 PM
