Old 05-30-2015, 11:40 PM   #1
frs_94
Drives: scion frs
Damaged tire
Noob question
So i bought these rims and tire and after about 500km they start leaking so i bought new ones and had them put them on and i told them i wanted the old ones back...this is what i got
they told me that the tire got damaged from stretching them.
does that seem right or did they damage the tire while un mountin them.
frs_94 is offline   Reply With Quote
Old 05-31-2015, 12:57 PM   #2
sirsol66
Drives: 2013 FRS- Hot Lava
The first photo is a torn apex. That's from mounting damage.
Your 2nd photo is a kincked (or possibly broken) bead. That's also from mounting damage.
If you're tire is mounted, you'll unseat the bead from hitting something (i.e. curb) before you kinck the bead. Both of those are 99.999% from mounting damage.
Source: I'm a tire engineer.
sirsol66 is offline   Reply With Quote
Old 05-31-2015, 12:58 PM   #3
frs_94
Drives: scion frs
Thank you @sirsol66
Old 05-31-2015, 01:09 PM   #4
sirsol66
Anytime. I had a shop bend the bead on a brand new set of Z2's and try to pass it off as nothing.
If the bead is actually bent, you'll probably just have an air leak (as you did). If the bead is broken..well, things like the Firestone for the Ford Explorer can happen.
Damaged my apr splitter Rocket.BRZ Cosmetic Modification (Interior/Exterior/Lighting) 23 07-18-2018 10:16 PM
sold BRZ'13 Canada Classifieds 1 08-15-2014 12:04 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
Already damaged paint... ktulu7 Scion FR-S / Toyota 86 GT86 General Forum 20 05-09-2013 07:13 AM
