Old 07-12-2014, 09:57 PM   #1
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Damaged my apr splitter
Hit a speed bump and damaged my splitter. Anybody have an idea on how I should go about fixing this?
Rocket.BRZ is offline   Reply With Quote
Old 07-12-2014, 09:59 PM   #2
Rocket.BRZ
The splitter itself is ok except for the clear coat. I need a new rod and the rubber seal that goes on the front. Could a body shop fix the clearcoat?
Old 07-12-2014, 10:12 PM   #3
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
If you're sure that only the clearcoat is damaged then yes a body shop could probably fix it. Contact APR to get replacement parts for the other stuff.
Next time slow down and avoid the bumps, the girl might be legal age by the time you get there.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 07-12-2014, 10:49 PM   #4
Dezoris
Dezoris's Avatar
Take the splitter off for street use. Its a functional aero item for track only. You will likely need to replace it, unless body shop can cut it and reclear but thats going to cost your probably $200
Old 07-13-2014, 12:16 PM   #5
charged86
charged86's Avatar
that stinks put some clear nail polish in the cracks to prevent water from soaking the fiber. man the stabilizer threads hit the bumper.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-13-2014, 01:05 PM   #6
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
ill buy it for 3.50
Thunderleg is offline   Reply With Quote
Old 07-13-2014, 01:32 PM   #7
Rocket.BRZ
How do I know for sure the splitter isn't damaged? If you take the rubber off the splitter is ok. And I don't see anything cracked underneath. So my best guess it's only the clear coat. It appears that the impact was mostly absorbed by the rod.
Old 07-13-2014, 02:50 PM   #8
sklimo
Car is totaled. Get rid of it
Old 07-13-2014, 03:49 PM   #9
husker741
Originally Posted by Thunderleg View Post
ill buy it for 3.50
I'll raise it to $3.51.
husker741 is offline   Reply With Quote
Old 07-13-2014, 04:39 PM   #10
sklimo
I'll go to $13.00 cuz relevant
Old 07-13-2014, 05:03 PM   #11
kavanagh
Fat on Corn Syrup
I thought it was $15.00 now?
Old 07-13-2014, 06:49 PM   #12
Rocket.BRZ
Originally Posted by Wonderbar View Post
The @hancha @eric6 @plucas FT-86speedfactory and Driveway Labs one can take a beating without being worthless, and it's perfectly suitable for daily use. Why buy parts when you can't use them all the time?
The speedfactory one is ok but it doesn't look good in my opinion. You have to consider my car is lowered.
Old 07-13-2014, 07:02 PM   #13
psybre
psybre's Avatar
I know with carbon fiber bicycles you can do a tap test and "listen" to the integrity of the piece. Basically, take a coin and tap the area around the damage. A dead, flat sound means it's broken, where as a more resonant, ringing sound means the structure is intact.
My guess is the carbon fiber is damaged at the connection point, and will probably need to be patched up or (lazy, maybe cheaper solution) have a metal plate or something installed for the rod to connect to.
psybre is offline   Reply With Quote
Old 07-13-2014, 07:10 PM   #14
Gunman
Drives: 2019 Mazda Miata RF
Switch to cables, instead of stay rods, to allow the splitter to move up when it makes contact, but it still holds it up from aero loads.
As for repair...you could try just having it clear coated, which may help cosmetically. Structurally, I'd say you'd have to cut out a pocket, install a new hard point, and relaminate...won't be as pretty then though. A good composite shop could do it for you.
Gunman is offline   Reply With Quote
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
Already damaged paint... ktulu7 Scion FR-S / Toyota 86 GT86 General Forum 20 05-09-2013 07:13 AM
clear bra damaged triwoody Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 03-17-2013 03:10 AM
Wind Damaged BRZ's thermobox BRZ First-Gen (2012+) — General Topics 6 08-25-2012 10:25 AM
Wind damaged BRZ's thermobox Scion FR-S / Toyota 86 GT86 General Forum 2 08-24-2012 04:23 PM
