Old 06-23-2015, 11:50 AM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Oil temp sensor install help
I got the innovate mtx-d oil temp/pressure gauge. Pressure will b coming from the galley plug, but no idea where to put the huge oil temp sensor. Too big to T off the oem 1
Pic for reference
lbroskee is offline   Reply With Quote
Old 06-23-2015, 11:58 AM   #2
Tareim
Drives: 2013 Subaru BRZ
get a sandwich plate for the oil filter area?
Tareim is offline   Reply With Quote
Old 06-23-2015, 12:02 PM   #3
lbroskee
lbroskee's Avatar
Already got my oil cooler there and I've had bad experiences with doing things like that and a gasket going out
Old 06-23-2015, 12:20 PM   #4
Tareim
T off the oil cooler? Not ideal but will work if you put it in pre cooler
is there a oil temp sensor installed from factory? nEEdLzZz BRZ First-Gen (2012+) — General Topics 16 09-14-2019 06:23 PM
Coolant temp sensor adaptor/Rad hose inner diameter brianL. Engine, Exhaust, Transmission 1 06-19-2015 03:21 PM
Oil pressure and Oil Temp sensor - where did you mount them and how philooo Engine, Exhaust, Transmission 11 05-29-2015 02:41 AM
Eng coolant temp sensor location D K Engine, Exhaust, Transmission 28 08-27-2014 05:30 PM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 10:38 PM
