Old 09-12-2012, 04:04 PM   #1
Wesley
Chen
Wesley's Avatar
Drives: RockyMountain bicycle bi-turbo '08
Hub Bore Correction
Hey guys, just wondering if it's reliable to correct a hub bore size that's too big with a spigot ring. Thanks a lot.
Wesley.
Wesley is offline   Reply With Quote
Old 09-12-2012, 04:32 PM   #2
seeclass
Drives: WRX
Yes, hub rings are recommended.
seeclass is offline   Reply With Quote
The Following User Says Thank You to seeclass For This Useful Post:
Wesley (09-12-2012)
Old 09-12-2012, 04:54 PM   #3
Wesley
Chen
Wesley's Avatar
Is that the safest way @seeclass?
Old 09-12-2012, 04:57 PM   #4
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Our Subaru Hubs are 56.1, depending on the wheels bore you should be fine because our wheel bores are so small the hub rings will be thick enough that they shound't wear due to guage thickness.
Spartan65 is offline   Reply With Quote
Old 09-12-2012, 09:24 PM   #5
Wesley
Chen
Wesley's Avatar
Great thanks, one of the bores i think are 76.1. What would happen if an aftermarket rim bore size is less than that of the FR-S'?
Old 09-12-2012, 11:59 PM   #6
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
If the wheel bore size is too small the wheel wont fit, you will ether have to have it bored out on a CNC Lathe or have the wheels ordered with a custom bore from the factory.
My SSR Type C wheels have a bore of 72.5 and came with centering rings that converted it from 72.5 to 56.1 for a perfect fit. They are highly recommended if you track your car or if you live in an area with lots of potholes or rough roads.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following User Says Thank You to Sony For This Useful Post:
Wesley (09-13-2012)
Old 09-14-2012, 07:53 AM   #7
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Ok, so Spartan & Sony confused me. What's our hub bore on the FR-S
karma003 is offline   Reply With Quote
Old 09-15-2012, 12:21 PM   #8
RavSpec
Drives: Rx7
5x100 Subaru hub bore is 56.1.
After market wheels have different bore.
So its always x > 56.1 hub rings.
X is the bore size for aftermarket wheels.
JDM wheels usually 60mm to 65mm as that's the minimum requirement to pass VIA/JWL standard (Japan equivalent to DOT).
If X is smaller than 56.1 I'll suggest u don't buy the wheels.
Its perfectly fine to use hub rings. Should be around $20 for one set.
RavSpec is offline   Reply With Quote
Old 01-02-2013, 08:00 PM   #9
seeclass
Drives: WRX
If you're trying to fit scion wheels, they will NOT fit. Scions have a 54.1 center bore. You can have them machined but it's kinda expensive. Most after market wheels come with a 73.1 center bore and some rays wheels come with a 65mm center bore.
Delete driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-08-2012 06:25 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
W221 S550 2 step correction CU2MIKE Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 06-07-2012 12:08 PM
M-Benz C300 Paint Correction OTD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 05-16-2012 08:18 PM
