Old 06-03-2015, 11:52 AM   #1
Frsultramarine15
Drives: 2015 scion frs ultra marine
Exclamation Help check engine light
I installed my ofh and tuned it to the stage 2 using open flash tablet. I got cel code p2097 i have no exhaust leaks i got it on a lift and checked everything any ideas on what might be going on. I searched but didnt find to much thanks.
Frsultramarine15 is offline   Reply With Quote
Old 06-03-2015, 11:57 AM   #2
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Need to disable the rear O2 or else you have a leak around the O2 sensor.
2016 Camaro SS is offline   Reply With Quote
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
Frsultramarine15 (06-03-2015)
Old 06-03-2015, 12:12 PM   #3
Frsultramarine15
How do i do that? Sorry still a noob.
Old 06-03-2015, 12:25 PM   #4
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Doesn't the tune disable the o2 once it is loaded?
Old 06-03-2015, 12:33 PM   #5
2016 Camaro SS
Drives: Fast
I'm not sure about OFT. My tuner for Ecutek had to disable the code manually.
Old 06-03-2015, 12:41 PM   #6
Frsultramarine15
From what ive heard it supposed to do it for you but im now sure. I have a test pipe at home if i install that will it get rid of the code?
Old 06-03-2015, 01:04 PM   #7
2016 Camaro SS
Drives: Fast
No. The code is caused by the secondary O2 sensor in the header. The front pipe changes nothing but sound in this case.
Old 06-03-2015, 01:48 PM   #8
Frsultramarine15
Hmmmmmmmm how do you disable it manualy?
Old 06-03-2015, 03:18 PM   #9
2016 Camaro SS
Drives: Fast
@Shiv@Openflash
He should be able to help you unless other OFT users chime in here.
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Check engine light? czar07 AUSTRALIA 0 09-01-2012 02:50 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 09:50 PM
