Old 05-28-2015, 09:54 PM   #1
philooo
Drives: 13' Scion FRS Track car
Is there a header providing performance gain and stay cool like OEM ?
Ok it seems most header are bringing some nice performance gain but I can see that the factory header has massive heat shielding around it.
Reading the forum I see that many have problem with heat after installing headers. Mainly the infamous coil problem for those who track their car.
are there any headers addressing this reliability issue ?
are coating effective ?
are heat wrap effective ?
I don't want to have to heat wrap everything around the engine to gain a few HP...
philooo is offline   Reply With Quote
Old 05-28-2015, 10:55 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Ceramic coat.
Tune your fans to keep your engine bay vented under a certain speed.
Old 05-28-2015, 11:01 PM   #3
s30series
Drives: 2015 BRZ Series.Blue
Its called ceramic coating and Ti heat shield wrap
I posted a long write up tempatures pre and post ceramic header install.....
s30series is offline   Reply With Quote
Old 05-28-2015, 11:42 PM   #4
Sleepless
Drives: 2016 FR-S
Ceramic coated OFH and no issues even at the track so far
Sleepless is offline   Reply With Quote
Old 05-29-2015, 12:06 AM   #5
That heat shield doesn't prevent the coil pack problem from happening. In fact, it's worse because the OEM header also has a cat, which retains heat pretty hardcore...
Old 05-29-2015, 12:14 AM   #6
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
You have got options here:
1: Ceramic Coat
2: Heat Wrap
3: Combine 1 and 2
4: Exchange hood for vented version
5: Combine 1, 2, and 4.
The key is to reduce radiating heat and reduce the closed oven approach to cooling.
killerkid08 is offline   Reply With Quote
Old 05-29-2015, 12:30 AM   #7
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
1: Ceramic Coat
2: Heat Wrap
3: Combine 1 and 2
You could also fab some heat shields to deflect radiant heat for the coilpacks and other vital sensors in that area.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 05-29-2015, 01:05 PM   #8
philooo
aren't you guys in the fabrication business of some sorts
I think that may be an interesting product to think about.
Old 05-29-2015, 01:22 PM   #9
Jesse@JDLAutodesign
It's in the works at some point...not enough time in the day or days in the week!
Old 05-29-2015, 02:11 PM   #10
DarkSunrise
DarkSunrise's Avatar
I'm using a ceramic coated catless header and haven't had any issues with coil packs at the track. It does get super hot and I can feel waves of heat pouring out from the front right fender area after sessions. It's probably a combination of heat from the header/OP and brakes. I just make sure to keep my hood open to let that heat vent out between runs. If I could do it again, I'd probably ceramic coat my OP as well.
2022 BRZ Build
2013 FR-S Build
Old 05-29-2015, 02:23 PM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
You sound like you could use some hands. Two to be exact, these two.
My informal application only fabbing experience i have is building legos and some middle school metal shop with an acetaline torch and mild sheet metal. Perfect canidate lol
Old 05-29-2015, 02:37 PM   #12
JB86'd
JB86'd's Avatar
Drives: JAWS
I'm running the OFH ceramic coated, everything else stock. I've logged engine oil temp before and after on several occasions and it seems that my oil temp stays a bit lower now with the OFH. This wasn't a controlled test by any means, and I can't say anything about radiant heat hurting engine components, just a casual observation.
No cat and a less crowded engine bay plus ceramic coating theoretically should mean less heat..at least in my mind!
Old 05-29-2015, 02:37 PM   #13
Cartman
Cartman's Avatar
Drives: GT86
I have uncoated aftermarket header and have no heating issues at all and i track my card hard... I do have an oil cooler though
Cartman is offline   Reply With Quote
Old 05-29-2015, 10:29 PM   #14
philooo
may be I can try to add a switch on the dash to trigger the radiator fan
I'll have to look into it, I bet something has that done somewhere already
ZN Performance - Stay Away boucher User/Vendor/Sponsor Reviews, Feedback, Comments 21 09-14-2014 08:40 PM
Keep Calm and Stay Cool With FR Sport's Summer Maintenance Special FRSport.com Miscellaneous 0 06-20-2014 12:24 PM
Stay Cool This Summer With Perrin and Koyo @ RallySportDirect.com RallySport Direct Engine, Exhaust, Bolt-Ons 12 09-11-2013 03:55 PM
*NEW* Scion FR-S Front and Rear Carrier/Stay Bushings | TWM Performance TWMPerformance Transmission and Driveline 0 02-25-2013 05:31 PM
Warm vs cool Weather performance EsoBOFH Scion FR-S / Toyota 86 GT86 General Forum 22 07-10-2012 11:45 AM
