Old 05-28-2015, 08:39 PM   #1
impossible
RS05RR or RPF1 for handling and track
Hi guys just want some feedback which wheels will be best for handling and track? wither RS05rr or RPF1. looking to get 17x8 et45 for rpf1 and 18x8.5 et38 for rs05rr.
impossible is offline   Reply With Quote
Old 05-28-2015, 09:13 PM   #2
8R6
8R6's Avatar
Drives: FRS
your tire choice will make a bigger difference than picking between those two wheel options.
8R6 is offline   Reply With Quote
The Following 2 Users Say Thank You to 8R6 For This Useful Post:
continuecrushing (05-29-2015), wparsons (05-29-2015)
Old 05-28-2015, 09:24 PM   #3
ryoma
ryoma's Avatar
from the sizes, looks like the RPF1 will be lighter and thus "better handling"
but really though, I agree with 8R6; it depends on your tire choice and how far you push it at the track. wheel weights won't make much of a difference if they're pretty close to each other. pick a wheel design you like.
I have no idea what the RS05RR are, but I do have RPF1's in 17x8 on my car with 235/45/17 dunlop direzza ZII tires. they're wonderful at the track though extremely lacking when not properly warmed up. I experienced that the hard way when I did a 360 pushing the car a bit too much on cold tires (first lap).
Old 05-28-2015, 09:45 PM   #4
juliog
juliog's Avatar
Drives: 86
The 18"s are generally heavier (hurts acceleration) and the narrow tire sidewalls make the ride harsher. 17" is the sweet spot for comfort and performance on this car.
juliog is offline   Reply With Quote
Old 05-28-2015, 10:11 PM   #5
impossible
thanks guys, while i know the tires and important but if i can get the light wheel which will reduce the weight isnt it? would like to put ad08r on either of these wheels.
Old 05-28-2015, 10:14 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
the weight is negligible when the wheels are close in weight. The RPF1's are probably slightly lighter, but this would be overshadow'd by the tire choice as that has to do with grip more than the weight of the wheel does.
More than likely, you wouldnt notice much of a difference in lap times with a slightly lighter wheel. You would notice a better lap time with a better tire.
I say RPF1's only because the RS05RR's are almost twice the price.
Old 05-28-2015, 10:48 PM   #7
jdmblood
jdmblood's Avatar
Drives: white subaru brz
look for rpf1s in 17 x 9. with a 245 width tire
jdmblood is offline   Reply With Quote
The Following 2 Users Say Thank You to jdmblood For This Useful Post:
Adrian002 (05-31-2015), Clipdat (05-29-2015)
Old 05-29-2015, 01:11 AM   #8
Higher Being
Drives: 2014 Asphalt Grey FRS
supposedly larger wheels can be more precise and less go cart like. Between the two, like everyone else has said you might net a little better acceleration from the rpf1's, but it would probably be due to you having less rotating mass than anything. I would say the rs05rr's are a better option if your car was a more serious track car. But both of these wheels are really popular for time attack builds, so neither are a bad option. Really the difference you experience from either option will be pretty negligible.
If it were me, id say the rs05rr's are better, simply cause I think they look better. haha
Cant go wrong really between the two.
Higher Being is offline   Reply With Quote
Old 05-29-2015, 06:44 AM   #9
Panman
Panman's Avatar
Drives: 86 GTS
In Australia the RPF1s are significantly cheaper than the RS05RRs - I run RPF1 17x9 +35 as my track wheels with Hankook RS-3s very happy with them bang for buck.
Panman is offline   Reply With Quote
Old 05-29-2015, 11:52 AM   #10
Gunman
Drives: 2019 Mazda Miata RF
I would guess that the RS05RR's are a bit stiffer than the RPF1's, due to the spoke design...if you are driving at 10/10ths, that can make a difference. For most humans, it won't matter.
Gunman is offline   Reply With Quote
Old 05-29-2015, 12:09 PM   #11
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
buy the wheel you want.
If you want to be speedracer, this is the wrong car. End of the day you will still be slow lol.
Jk. Sort of. Everyone always gets their panties in a wad/do a lot of "bench racing" of this is 2lbs lighter! Oh yeah? The square root of the coeffiecient allows alignment of the stars which enable altered gravity enabling faster speeds with a wheel that is wider with a lighter tire blah blah blah!
My math is here:
[ (15 m^3 n^(-2) p^(-1)) / (25 m^(-2) n^(-4)) ]^(-3)
The truth:
Are you really THAT fast of a driver to where the wheel you have is what is keeping you from being 0.001 faster?
No. No it is not.
The Following 3 Users Say Thank You to continuecrushing For This Useful Post:
8R6 (05-29-2015), cdrazic93 (05-29-2015), wparsons (05-29-2015)
Old 05-29-2015, 12:11 PM   #12
gramicci101
Off Topic
I vote for the RS05RR. Why? It looks better and nearly every other car out there has RPF1's on it.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
continuecrushing (05-29-2015), Synack (05-29-2015)
Old 05-29-2015, 12:40 PM   #13
Gunman
My math is here:
The truth:
No. No it is not.
I was honestly amazed that our drivers could tell the difference, as could the stop watch, when I worked for a IMSA race team. They tested 3 brands of wheels back to back once. Note: world class drivers.
...and did you carry the 2 up there?
Old 05-29-2015, 01:17 PM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I actually think he dropped the 2, it cancelled with the pi, im pretty sure. Unless my uneven obtuse geometry of oblong circles class tought me the wrong thing
♦♦♦ ENKEI WHEELS ♦♦♦ RPF1 in SBC, Silver & Black. RS05RR, RS+M, NT03+M Black & Gold FT-86 SpeedFactory Wheels and Tires 229 07-01-2016 10:41 AM
Best offset for RPF1 (+35 or +45) in 17x9 and track/AX use dp1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-19-2014 04:01 PM
2015 FRS track review - Scion tweaked handling srt4evah Scion FR-S / Toyota 86 GT86 General Forum 3 09-11-2014 07:42 AM
Track wheel Enkei RPF1 in 16" ?? stockysnail Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-07-2013 09:13 AM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
