Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Would the Enkei RPF1 in 16" fit our cars? Here's the stats from the tire rack website. Wheels are only $221 each. Tires are so much cheaper in these sizes as well.
Star specs only $129 each and RE11 only $163 each! (in 205/55R16 sizes)Enkei RPF1 Size: 16x7 Offset: 35mm Backspacing: 5.35" Bolt Pattern: 5-100 Rec. Tire Size: 205/55-16 Weight: 13.7lbs.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
Those aren't really made for the 86, but +35 would fit the car. I would never run that small and tall of a tire on our cars, it would be a huge decrease in performance. I'd save your pennies and buy some 17x8 RPF1s and get some 235 Star Specs instead.
Drives: Grey GT86 MT
The stock GT model in Australia comes with 16" rims and a 205 tyre by default. I made the jump to an 18" rim and 225 tyres. Your claims of a "huge decrease" in performance is a load of horse shit. I've done my fair share of spirited driving and the main difference I noticed was with the tyres themselves as I certainly didn't notice anything drastic that would make me believe my 18" combo created a 'huge increase' in performance.
Drives: 13 whiteout scion frs
No way your going to get much grip on the front enf with 205 the torque qil
Will lift up causiun understeer |
Just the tip
Good info thanks guys. 16 are so much cheaper but I was just curious as my primary option was 17x9 Enkei RPF1 with RE11 245/40R17. All that is pending someone buying my 18" forged Neuspeeds and the stock Primacy rubber I have sitting here.
Drives: Some rust bucket
Dude thats obvious
I never daid that
#10 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
225/50-16 should be a nice size on them.. I'm sure they have some great performance tires out there in that size right..
#11 | |
Drives: asphalt FR-S
#12 |
987 Motorsports
Drives: '13 WO FR-S
16x7 is way too small. it's not a miata. you can fit 17x9 under there with 245s for track duty. even 225s. i wouldn't go any smaller than a 17" wheel and 225.
#13 | |
Drives: GT86
Fact: a 16" will be even lower in weight and the rotational inertia will be less because of the smaller size even with the same weight. Even 15" would do fine. Of course you will need a proper tire with a stiff sidewall to make it perform! But the only actual racing reason to go big on rims, is because your brakes need to fit. So unless you have (need?) a BBK or are running 400HP and need massive grip from a 9,5" wide rim, small rims are just fine for the track. |
#14 |
Drives: GT86
16"
![]() 15"
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
| F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires | SsmoothyMonster | Wheels and Tires | 17 | 09-24-2012 01:52 AM |
| 18" ENKEI Racing RPF1 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 08-30-2012 07:11 PM |
