Old 05-24-2015, 09:40 AM   #1
mattlang89
mattlang89's Avatar
Drives: 2013 Boosted GT86
Greddy oil cooler to cold
I have just recently started running my greddy oil cooler i think i have hooked it up correctly but the temp for normal driving sits at about 70 degrees C.
I believe the target should be about 82. I have i set it up wrong or can i adjust the thermostat?
Also i have my oil temp sensor in the sump. Not that that should make any difference.
mattlang89 is offline   Reply With Quote
Old 05-24-2015, 11:03 AM   #2
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
How cold is it there? That's my normal temp just driving home when it is 50F here. That is staying out of boost and cruising for about 10 miles.
Build Thread
Instagram
Old 05-24-2015, 12:17 PM   #3
mattlang89
mattlang89's Avatar
Ambient temperature is around 25 C at this time of year.
From what I am told that's to cold of oil temp. Are you runing the greedy cooler too?
Old 05-24-2015, 12:34 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
adjust the stat. Unless is stock, then buy a new one
Old 05-24-2015, 12:41 PM   #5
DarkSunrise
DarkSunrise's Avatar
Sounds like you need to block off airflow to the cooler using a block-off plate.
I use my front license plate since my Perrin oil cooler is center-mounted:
With the block-off plate installed, in 70 F (21 C) ambient temps, my oil temps will sit right around 182-185 F (83-85C) on the highway.
When I get to the track, I pull my license plate off to let airflow to the cooler.
2022 BRZ Build
2013 FR-S Build
Old 05-24-2015, 12:47 PM   #6
mattlang89
mattlang89's Avatar
Do you know what brands make a adjustable stat? I am pretty sure that my greedy one isn't.
Gushi installs a Greddy Oil Cooler TAP Auto Parts Scion FR-S / Toyota 86 GT86 General Forum 27 05-08-2013 03:51 AM
Question about Greddy oil cooler Captain Snooze Engine, Exhaust, Transmission 3 09-10-2012 03:40 AM
Greddy oil cooler coming soon DIG1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 08-20-2012 12:02 AM
Greddy Oil and Diff Cooler pdreams Engine, Exhaust, Transmission 3 06-13-2012 08:41 PM
