Old 05-17-2015, 11:22 AM   #1
raven1231
Borla UEL vs. Nameless EL with FI
I'm getting the WORKS turbo kit on Wednesday and was wondering whether or not the BORLA UEL or Nameless EL would be better for forced induction? I know people tend to say EL > UEL but also from what I'm reading Short tube > long tube. So, I was wanting to know what your guy's opinions are on this? The turbo will only be pushing between 7.5 psi on stage 1 and eventually 12.5 psi -16 on stage 2 when I upgrade down the road. I also will be using a full cat less 3" exhaust. Thanks!
P.s. I'm not looking for opinions on the WORKS turbo kit...
Old 05-17-2015, 11:47 AM   #2
KoolBRZ
KoolBRZ's Avatar
(The turbo comes with it's own header. Neither header will work with this turbo. You can use different front and mid-pipes however, the bigger the better.) Wrong. See raven1231's comment below.
You may want to get the header, up-pipe, and down-pipe epoxy thermal coated before you install, to keep from melting any important engine components.
Watch your intake air temperatures if you get stuck in stop-and-go traffic. This may be your only clue to how high your under-hood temps get. The Works kit is at least rear-mounted, so you won't have to worry about melting radiator fans, and heat-soaking the intake.
A turbo provides it's own back-pressure, so any additional back-pressure from the exhaust/muffler hurts the performance, but free-flowing exhaust can be loud and raspy. A good muffler setup is large, free-flowing, and has Helmholst resonators to eliminate rasp.
Old 05-17-2015, 12:06 PM   #3
raven1231
Works uses the stock header.
Dream20b (05-17-2015)
Old 05-17-2015, 12:10 PM   #4
raven1231
And ghost is using the open flash header on his, and someone else is using the p and l el on theirs.
Old 05-17-2015, 02:22 PM   #5
KoolBRZ
KoolBRZ's Avatar
Can it mate up to a (Nameless EL) PLM long tube headers' 3" flange? If so, that will give it more low-end torque.
Old 05-17-2015, 03:12 PM   #6
raven1231
I'd assume since the nameless header is supposed to work with any exhaust that mates up to the factory header
Old 05-17-2015, 05:39 PM   #7
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
What I was told was, unless you're aiming for high hp get EL. If you just want a car that has more spunk and love the rumble UEL will do. But looking on the forum, i saw somebody pushing almost 400whp on the AVO turbo kit which is UEL. I suppose it's all personal preference.
Low&Slow is offline   Reply With Quote
The Following User Says Thank You to Low&Slow For This Useful Post:
raven1231 (05-17-2015)
Old 05-17-2015, 05:59 PM   #8
Dream20b
Y u do dis?
I went with Tomei EL headers on my sprintex supercharger kit, I think the EL headers are more sleeper since you don't get that burble. I would apply the same logic to this and go with EL headers. I'm running a 70mm pulley so that's about 11.5 PSI if I recall.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 05-17-2015, 06:21 PM   #9
raven1231
Thanks! I'm just wondering if them being long tube headers will hurt performance when going FI.
Old 05-17-2015, 06:39 PM   #10
Dream20b
Y u do dis?
I would venture to say that running an EL header will not only provide small benefits to horsepower over UEL, but will also move heat away from the engine more evenly.
Dat Hot Lava Doe
Old 05-17-2015, 06:47 PM   #11
raven1231
I've just heard that long tubes may hurt spool when going fi. Was hoping someone might know.
Old 05-18-2015, 07:03 PM   #12
raven1231
Think I'll just stick with the BORLA UEL. I'm not so sure it will really matter at lower boost levels anyway, and the long tubes may hurt spool time.
JDL UEL + Nameless FP/OP + Borla Catback autograph Engine, Exhaust, Transmission 10 04-20-2015 07:04 PM
Borla Exhaust or Nameless? mervingee Engine, Exhaust, Transmission 12 06-21-2014 09:50 AM
Borla UEL + Nameless DP/OP + TRD Catback? liajet24 Engine, Exhaust, Transmission 0 04-03-2014 01:55 PM
Anyone compare the Borla Catback vs Perrin or Nameless? Vmax911 Engine, Exhaust, Transmission 7 06-16-2013 10:52 PM
Borla UEL, Stock Exhaust, Nameless Axle Back @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 8 03-23-2013 11:41 PM
