Old 04-19-2015, 03:21 PM   #1
autograph
autograph's Avatar
Drives: 6MT Hot Lava
JDL UEL + Nameless FP/OP + Borla Catback
Took a video of cold start and revs, revs start around 1:00.
To be honest I'm a little dissapointed. In car, it sounds amazing. But from what I can tell from this video, it sounds tinny / raspy in the high RPMs from behind the car. A bit dissapointed. Was hoping it would be deeper sounding. :[ Waited 4.5 months for the JDL UEL header (installed the header / fp + op at the same time. Borla catback has been on for a long while)
autograph is offline   Reply With Quote
Old 04-19-2015, 03:45 PM   #2
ryoma
ryoma's Avatar
keep mind that most cameras don't have microphones that can pick up the exhaust note exactly like it is when in person.
Old 04-19-2015, 08:57 PM   #3
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
Yea I would suggest getting someone to drive your car so you can hear !
You might be more pleased with the result !
Pish is offline   Reply With Quote
Old 04-19-2015, 10:16 PM   #4
autograph
autograph's Avatar
thanks for the encouragement guys haha. maybe the camera has something to do with it. we'll see
Old 04-20-2015, 12:20 PM   #5
kdmxdgt
Drives: 2014 WR Blue BRZ Lmtd
Both the camera and quality of the speakers you are playing it back on will affect how accurate the sound recreation is. If ur exhaust sounds deep in person make sure u have good bass reproduction when playing it back
kdmxdgt is offline   Reply With Quote
Old 04-20-2015, 12:23 PM   #6
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
You can always put on an Invidia N1 if you want real deep, loud, and drone. Sounds pretty incredible if you don't mind the drone\vibration a bit.
2016 Camaro SS is offline   Reply With Quote
Old 04-20-2015, 12:31 PM   #7
kdmxdgt
Or a evo3 👍
Old 04-20-2015, 05:15 PM   #8
DM7
Drives: '13 FR-S Argento
Does your over/front pipe have a resonator in it?
After personally watching way too many exhaust clips I have noticed that front pipes that have resonators do not have the tinny/raspy sound at higher rpm.
For whatever reason resonators in cat-back systems do not seem to eliminate that sound.
I have embedded two videos. The first video has no cat and no resonator in the front pipe (raspy) whereas the second video does (no rasp).
Video 1) JDL
UEL header
Overpipe
Front pipe (no cat, no resonator)
D2 cat-back exhaust (resonator, muffler)
[ame="https://www.youtube.com/watch?v=8oG-VtqTrsU"]JDL Auto Design Header back full 2.5" exhaust startup - YouTube[/ame]
Video 2) JDL
UEL header
Overpipe
Front pipe (cat, resonator)
[ame="https://www.youtube.com/watch?v=F_EdwFKDJMI"]JDL Auto Design Header back full 2.5" exhaust startup - YouTube[/ame]
I know the last thing you need is to spend more money but it looks like the best solution.
DM7 is offline   Reply With Quote
Old 04-20-2015, 05:46 PM   #9
EpicNameBro
Drives: Slow...
Is your front pipe combo catted? If it's not there is your problem right there. If it is you need to look into adding a resonator. Exhaust sounds fine to be in the video but everyone's taste is different...
EpicNameBro is offline   Reply With Quote
Old 04-20-2015, 06:27 PM   #10
autograph
autograph's Avatar
@EpicNameBro and @DM7 yes my front pipe is both catted and resonated. maybe its the borla catback and its muffler? *shrugs* maybe i should add another resonator? it is worth noting that the nameless fp/op use a "ball" type resonator now because of past fitment issues. dont know if this ball design is as effective
Old 04-20-2015, 07:04 PM   #11
EpicNameBro
Drives: Slow...
Well damn that makes it interesting. It very well could be either or in that case. Exhaust do vary greatly, but Nameless also has had documented issues with their FP/OP as well and I can say that from experience. If I didn't have so many things going on I would get rid of mine, but for now I just deal with it. I will more than likely go JDL UEL/OP and FP...
Borla Exhaust or Nameless? mervingee Engine, Exhaust, Transmission 12 06-21-2014 09:50 AM
Nameless Catback roosahorn Southern California 2 06-12-2014 05:42 PM
Borla UEL + Nameless DP/OP + TRD Catback? liajet24 Engine, Exhaust, Transmission 0 04-03-2014 01:55 PM
Anyone compare the Borla Catback vs Perrin or Nameless? Vmax911 Engine, Exhaust, Transmission 7 06-16-2013 10:52 PM
FS: Borla-Catback!! FT-86- Engine, Exhaust, Bolt-Ons 16 03-07-2013 02:15 AM
