SLO NO MO
Pressing Brake Turns off Clock/Dims Navi
Looks like I have a wiring issue somewhere. Anyone ever encounter this?
I press the brakes and the clock shuts off and the navigation map goes into night mode. I let up and it goes back to normal. With headlights on, everything works normally. Grounding problem somewhere? Sent from my Nexus 4 using Tapatalk 4 |
NASA SpecE30 Racer
Do you have OEM taillights?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
SLO NO MO
Drives: FR-S 6MT
Ghosts.. It's the only logical explanation.
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
That, or the dragons again.
Double check the connections on any aftermarket lighting. I don't know much about Tom's, but if it requires re-wiring that would probably be the first suspect. It's an off-chance, but LEDs also give off RF radiation that can interfere with electronics. Cars designed for them have fewer problems, but for instance, when I put aftermarket LED bulbs in my Outback they started causing radio interference (especially in the morning). I don't know if the stock lights are RF shielded (like speakers), but there's a good chance aftermarket ones aren't. Although I don't have any problem with my Valentis. |
SLO NO MO
Checked everything out - looks like the Tom's tails were fine, it's my Phastek rear fog/fourth brake light that is dead, and for whatever reason, that dying caused weird things to happen elsewhere. Not sure if the bulb is toast or if something else is, but taking the bulb out of the Phastek socket made everything work like normal again.
Bulb doesn't looked burned out, it's a Sylvania 3157K which goes for about a buck, so I'll pick one up and see if that solves the problem. |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
Sometimes being an early adopter isn't so much fun.
Google brz wiring and click first link, Page 148 onwards The part where you say everything works with headlights on concerns me Get rid of the rear fog lamp and toms and revert to oe and tell us what happens Have you disconnect battery and retried? |
Sarcastic SOB
something is touching ground from physical contact when you press the brake.
I could walk you through the steps to try and narrow down the source (I did this with many pinball machine malfunctions), but you have a warranty!!
In Test:Oil Fed SC
Have you checked brake (the call it 'stop' ) lamp fuse? Or whatever you tapped phastek gizmo into?
#10 |
Sarcastic SOB
The bulb out might indicate overvoltage. If the next one blows quick theres a hot wire touching the positive wire the lamp.
If the bulb never works there's a dead short. Take it to the dealer you have a warranty. Remove all electrical mods including the tails first. The isuse might disappear.
#11 |
SLO NO MO
Replaced the fourth brake / rear fog light bulb and now everything works as expected. I'll keep an eye on it to see if there's an underlying problem.
Thanks for all the suggestions guys! |
#12 |
In Test:Oil Fed SC
You needs a diode somewhere I suspect
#13 | |
NASA SpecE30 Racer
- King Tut
#14 | |
SLO NO MO
| DIY-- How to bypass your NAVI without moving out your NAVI (Canadian BRZ only) | 8987846 | DIY (Do-It-Yourself) Guides | 77 | 04-29-2015 01:45 PM |
| Pressing/releasing clutch pedal - audible click sound (not the clutchs switch | tanner | BRZ First-Gen (2012+) — General Topics | 26 | 06-03-2014 08:24 PM |
| Bypassing your NAVI without moving out your NAVI | 8987846 | CANADA | 0 | 12-24-2012 02:20 AM |
| CLOCK QUESTION | poudre | BRZ First-Gen (2012+) — General Topics | 16 | 07-02-2012 02:20 PM |
| Details: Interior dims, glass, light bulbs | Ryephile | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-01-2012 10:28 AM |
