Old 05-15-2015, 12:50 PM   #1
ShackontheTarget
ShackontheTarget's Avatar
Drives: GT86 Aero
Engine whistle between 2-2.5K RPM
Hi,
As the title says, I've noticed for the first time today that the engine, or so I presume, makes a light whistling noise when I'm between 2000 and 2500 RPM. It happens in all gears and idle. I've had the car for 5 months now, from new, first time I've encountered this. I could actually hear it whistle a little bit when I started it up, on cold idle.
Any idea what it could be?
Thanks... and sorry if this has been covered somewhere before, couldnt find anything with a quick search.
ShackontheTarget is offline   Reply With Quote
Old 05-15-2015, 02:14 PM   #2
Koa
peep my signature about how to search this site more efficiently... in a nutshell,
1. Go to Google.com
2. Type in some key search terms relating to your query, followed by the following verbatim:
site:ft86club.com
What this does is specifically target searches within that domain, and all subdomains therein. The default search feature stock on the site sucks.
There's a lot of cool things one can do with google using their operators.. this one is by far the easiet and most relavent for most looking to parse a domain for info, though.
As far as your noise is concerned... this may be nothing, or it may be everything. Given what you describe, nobody can reasonably give you an answer to why your system is experiencing this noise. It would help to get a video up if you can replicate and capture the event taking place
Old 05-15-2015, 02:25 PM   #3
ShackontheTarget
Drives: GT86 Aero
Thanks for the search tips Koa.
I found out what it was, so silly. The silencer on the left exhaust tip had dislodged a bit, letting air through a gap I guess, between it and the tip's sidewall. Started up the car after 1hr "cool down", and the silencer was rattling a lot. Did some tests runs with and without them afterwards, no problems. I can sleep tonight.
whistle noise in 6th? Lydin Engine, Exhaust, Transmission 43 10-28-2016 02:45 PM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Turbo Whistle v. Blower Whine SupraLove Forced Induction 34 11-21-2012 08:56 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
