Old 05-11-2015, 11:04 AM   #1
IBill4You
Drives: 2015 Subaru BRZ
Negative Short term fuel trims at idle w/ no obvi leak
Has anyone encountered a turbo application that resulted in negative short term fuel trims at idle that range from 0% to -20% with no obvious vacuum leak?
FMIC setup with EBC and BOV
PCV Valve has been switched to an STI PCV Valve
added 9 Clamps to pcv system
EcuTek tuning
Throwing code P0068.
MAP sensor replaced with new Omni 3 Bar.
consensus is vacuum leak, but haven't been able to find a leak.
What could cause this?
Defective equipment?
Bad install?
Bad tune file?
Please don't say it has to be a vacuum leak?
HALP
log attached
Really stuck on this one.
File Type: zip NEWMAPNEWPCVVALVEIDLEDRIVINGANDPULLS.zip (103.0 KB, 151 views)
IBill4You is offline   Reply With Quote
Old 05-11-2015, 12:51 PM   #2
CSG Mike
CSG Mike's Avatar
Clean your MAF sensor.
Perhaps adding catch cans to your car will help, as could adding a check valve to your manifold to crank case line.
Old 05-11-2015, 01:48 PM   #3
IBill4You
I'll definitely take care of those.
The shop just said, "Your car isn't running timing"
any ideas on that?
The STI PCV Valve should be enough to prevent any vacuum issues that the check valve would address, but for a couple dollars I'll gladly install one.
Is this a mechanical or tuning issue?
Could this have happened after hard pulls for logging?
Old 05-11-2015, 02:29 PM   #4
CSG Mike
CSG Mike's Avatar
any ideas on that?
If it's a result of the hard pulls, then either something on your car changed (e.g. boost leak, dirty sensor, etc.), or the tune is bad and the ecu is compensating.
IBill4You (05-11-2015)
Old 05-13-2015, 08:29 AM   #5
bprayogo
Drives: toyota 86
Your advanced multiplier is 0.16 which is very very bad.the ignition will run on a retarded map . it knocks everywhere at medium load. It think the tune is bad . and the MAF scaling is way off . you're not geting enough fuel at medium load, hence the knocks .
bprayogo is offline   Reply With Quote
The Following User Says Thank You to bprayogo For This Useful Post:
IBill4You (05-13-2015)
Old 05-13-2015, 08:52 AM   #6
IBill4You
Vacuum leak was ruled out by a shop. They uninstalled and reinstalled the kit to check for DIY errors, of which thankfully there were few and none that would cause this.
I'm waiting on a new tune file to verify bad tune.
I have a gut feeling it is the tune, but I know part of that is a fear of what else it could be.
If it does turn out to be the tune, I'm going to have spent more than I paid for the tune to have it diagnosed and corrected. Not happy and miss my car either way.
Old 05-13-2015, 12:46 PM   #7
CSG Mike
CSG Mike's Avatar
Was the system pressure tested by the shop? If it was not, you have not yet ruled out a vaccuum leak.
If there were a few errors on your original DIY install, there can be more that isn't immediately obvious to the shop.
have you tried resetting the ECU?
I'm still gonna go with you have a leak somewhere.
The generic trouble code P0068 refers to an engine management problem. A disparity exists between the computer's sensors as to the volume of air entering the intake manifold.
The PCM relies on three sensors to indicate air flow volume in order to calculate fuel and timing tactics. These sensors include the mass airflow sensor, throttle position sensor and the Manifold pressure (MAP) sensor. There are many sensors on the engine however these are the three associated with this code.
Old 05-13-2015, 02:21 PM   #8
yonson
yonson's Avatar
Drives: slow
Vacuum leaks are generally followed by positive fuel trims because there is extra air being introduced to the engine that the MAF doesn't know about. Negative fuel trims are more indicative of airflow being less than expected due to clogged air filters, stuck bypass valves etc...
yonson is offline   Reply With Quote
The Following User Says Thank You to yonson For This Useful Post:
aagun (05-13-2015)
Old 05-13-2015, 02:51 PM   #9
aagun
Drives: 86
Negative fuel trims means also fuel leak
aagun is offline   Reply With Quote
Old 05-13-2015, 03:17 PM   #10
aagun
Drives: 86
from ur log
high pressure pump not normal
idle goes rich and normal like a waves
Old 05-13-2015, 03:24 PM   #11
aagun
Drives: 86
http://www.ft86club.com/forums/showthread.php?t=56392
The Following User Says Thank You to aagun For This Useful Post:
IBill4You (05-14-2015)
Old 05-13-2015, 05:37 PM   #12
CSG Mike
CSG Mike's Avatar
Pressure test -_-
Old 05-13-2015, 05:44 PM   #13
yonson
yonson's Avatar
Drives: slow
Yeah, a smoke test should be the first thing performed once any forced induction system has been added...
CSG Mike (05-14-2015)
Old 05-17-2015, 08:24 PM   #14
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
Any solution?
RD1428 is offline   Reply With Quote
Fuel trims abnormal after cleaning intake. feldy Engine, Exhaust, Transmission 8 04-16-2014 04:48 PM
Fuel trims video mike_ekim1024 Software Tuning 1 12-20-2013 08:01 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
