Old 05-09-2015, 01:36 AM   #1
Euro7R
Drives: 2013 Subaru BRZ
Rear Differential Oil Change - How Often?
How often do you guys change your rear differential fluid?
I changed my first one last summer. I am thinking of changing it some time soon, but not sure if it's a time interval or certain mileage I am supposed to do it at? Even my oil changes, I do it every 4 months regardless.
Euro7R is offline   Reply With Quote
Old 05-09-2015, 02:48 AM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I waited until 30k but I wish I changed it at 15k or 10k even. There are a lot of stuff on that magnetic .. I plan on changing it out again at 40k.
Old 05-09-2015, 12:13 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
It may or may not be necessary, but I change mine once a year, usually around the holiday weekend in May. I change the transmission fluid (manual) at the same time. That works out to every 25,000kms or so.
@Bonburner...the 1st change always looks kind of scary. You wont see as much on the next changes even if you go as long on the interval. When the gears are new, they need to "take a seat" to each other, and this produces the fine particles that make up the paste that's stuck to the magnet. IIRC, I first changed mine at 1,300 miles or so, and it was already pretty grungy looking. Each change after that has had less and less material on the magnet.
My personal preference for differential fluid is Redline's 75W85 high performance GL5 gear oil. I drive the FR-S all year as my daily driver. If it was summer exclusive, or the car saw some track duty, I would consider a 75W90.
The Following User Says Thank You to roddy For This Useful Post:
Bonburner (05-09-2015)
Old 05-09-2015, 12:16 PM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
My primary concern is if there is That much gunk on the drain plug then how much gunk is still in there - more flushes will extract more gunk lol
Old 05-10-2015, 02:49 AM   #5
Why not just change (clean off) the drain plug ..... ?? .....
Ultramaroon (05-11-2015)
Old 05-10-2015, 12:10 PM   #6
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
The problem is if there is gunk on the drain plug then there is More gunk inside as well - kind of like termites .. Sure you can kill off termites in this one spot but throughout the house there're more
The Following User Says Thank You to Bonburner For This Useful Post:
humfrz (05-10-2015)
Old 05-10-2015, 01:21 PM   #7
roddy
roddy's Avatar
The magnet on the drain plug does a good job of pulling the bad stuff out of the oil.
Old 05-10-2015, 07:00 PM   #8
Euro7R
There's no harm changing out the fluids sooner, I personally believe. It's relatively inexpensive maintenance.
Old 05-10-2015, 07:07 PM   #9
Ornelas66
Drives: 2015 Scion FRS
When you change the Differential Oil (or even the Manuel Transmission Oil) do you guys buy new crush washers, or reuse the originals?
Ornelas66 is offline   Reply With Quote
Old 05-10-2015, 08:15 PM   #10
gramicci101
Off Topic
They're gaskets, not crush washers. You can reuse them.
http://www.ft86club.com/forums/showp...0&postcount=49
The Following User Says Thank You to gramicci101 For This Useful Post:
Ornelas66 (05-10-2015)
Old 05-10-2015, 08:53 PM   #11
roddy
roddy's Avatar
I wouldn't re-use the ones on the diff, but no problems using the ones on the transmission a couple of times.
Old 05-10-2015, 11:16 PM   #12
Euro7R
^Yeah, the washers are cheap. I bought a few at my local dealership, came out to $1.50 each.
Old 05-11-2015, 12:56 AM   #13
SR5
SR5's Avatar
Drives: Raven
yes this is good thinking, see my post in the Pentosin vs Motul Thread: http://www.ft86club.com/forums/showthread.php?p=2244143#post2244143
Changed Diff fluid at 13,300 miles (21,404 km).
Oh and just remember there is no space above the fill plug, none! Bottles can be positioned only horizontally. I had to squeeze the hell out of 2 Motul bottles to get it to fill. And finally realized there is an inverted nipple in each bottle that can pulled out for better filling. Torque setting is higher for the Diff Plugs, so I used new crush washers.
something smelly, and you still have crickets..
SR5 is offline   Reply With Quote
Old 05-11-2015, 01:17 AM   #14
No. Your logic is flawed because you missed the main point of the magnetic plug. The gear teeth lap against each other during break-in. The magnet pulls the tiny steel particles out of suspension - permanently. There are no other termites in the house
The only reason to change the gear oil would be out of concern for viscosity breakdown, not pest control.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
akahenry (05-15-2015), brianhj (05-11-2015), humfrz (05-11-2015), roddy (05-11-2015)
WEIR Performance 4.56 FD & IS300 LSD Rear Differential SportInjected Transmission and Driveline 3 08-09-2014 09:36 AM
FS: Rear Differential with Cusco 4.55 Installed SOLD mrk1 Engine, Exhaust, Bolt-Ons 6 05-28-2013 01:34 PM
Eww rear differential goo LeeMaster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 04-10-2013 09:17 PM
Rear End/Gear/Differential Ratio fly2low Engine, Exhaust, Transmission 9 02-09-2013 11:53 AM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
