Old 05-06-2015, 02:08 PM   #1
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
Glovebox question
When you open your glovebox, does it just drop loosely down to the bottom, or is is damped at all?
The dealer had my glovebox out and now it doesn't feel quite like I remember it -- I sort of remember it being smooth/controlled to open and now it just dumps right to the bottom when I open the latch. Is that how it's supposed to be?
Jond63 is offline   Reply With Quote
Old 05-06-2015, 02:14 PM   #2
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
If I recall right is smooth down.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 05-06-2015, 02:21 PM   #3
CBR600RR
Drives: Raven Black
mine is not a smooth down
Edit: Maybe mine is smooth, I can't be 100% sure
Old 05-06-2015, 03:16 PM   #4
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Mine has one of those little dampers on it but it's never been very damped.
PWBRZ is offline   Reply With Quote
Old 05-06-2015, 03:51 PM   #5
ryoma
ryoma's Avatar
mine is damped, but very little. it still dumps open when you release the lever and don't support it. however, you can feel a little resistance but not much.
Old 05-06-2015, 07:39 PM   #6
roddy
roddy's Avatar
Drives: '13 Ultramarine
There is a small damper there. It just snaps in place. The tech may have missed it when he put things back together. I've had mine apart to change the cabin filter a few times now, and almost missed it myself the first time.
Open your glovebox, and look down the right side on the outside of the box, and you'll see a pin with a slot in it sticking out of the side of the box. There is a little "damper" that snaps over that pin. I'd bet that your damper is hanging free from it's upper mounting point. Grab it and snap the hole in the bottom over the pin on the side of the glovebox. Hope that helps.
Old 05-07-2015, 12:47 PM   #7
Jond63
Jond63's Avatar
***update*** Just double checked and pulled out the glovebox and stuffed way up in there was the tiny damper. Hooked it all back up and smooth glovebox action again!
Thanks much!!!
Yep, thanks -- I saw that pin which made me think there was something supposed to snap over it, but I can't find that part. Back to the dealer I guess...
Old 05-08-2015, 11:18 AM   #8
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
I checked mine out and in the process, unclipped it from the upper mounting. If this happens to anyone (damper drops, hangs loosely, ect), it's easy to put back, just make sure to use the lower hole on the damper (only 1 nub to attach to, one will be unconnected to anything), or your glove box will drop everything out every time you open it.
@Jond63, try squeezing both sides of glove box together to take it out completely, the damper may have fallen behind the glovebox.
V_86 is offline   Reply With Quote
Old 07-19-2020, 11:18 PM   #9
2017BRZ4ME
2017BRZ4ME's Avatar
Drives: 2017 Subaru BRZ Limited w/perf pkg
Still a handy thread in 2020, Thanks!
2017BRZ4ME is offline   Reply With Quote
So who likes having their USB in their glovebox ? BC-Boy Electronics | Audio | NAV | Infotainment 19 05-29-2014 11:53 PM
Glovebox LED light Install Tech DIY (Do-It-Yourself) Guides 0 03-26-2013 07:21 AM
Guess what i just foubd in my glovebox??? JPL321 Cosmetic Modification (Interior/Exterior/Lighting) 6 03-16-2013 01:16 PM
Random pin connecter above/behind glovebox Iddoit2er Electronics | Audio | NAV | Infotainment 6 01-13-2013 12:25 AM
Cable in glovebox KamalT AUSTRALIA 8 08-23-2012 07:52 AM
