Old 05-05-2015, 02:57 PM   #1
艾洛
艾洛's Avatar
Drives: Raven
245/40 on 17x7?
Sorry for another one of these questions! But it will be the first true summer with this car and I've been struggling on deciding what size of tire I should go for. I have settled with the Michelin's PSS.
A buddy of mine has recommended 245/40s in comparison to the 225/45 and 235/45.
What are your thoughts?
艾洛 is offline   Reply With Quote
Old 05-05-2015, 02:59 PM   #2
swarb
I think you should read the tire specs and look and the minimum wheel width.
The Following User Says Thank You to swarb For This Useful Post:
wparsons (05-06-2015)
Old 05-05-2015, 03:02 PM   #3
adamg
Drives: brz
good luck
adamg is offline   Reply With Quote
The Following User Says Thank You to adamg For This Useful Post:
Old 05-05-2015, 03:08 PM   #4
MrBlaze-65
Drives: 2014 Subaru BRZ
You're tinkering around the same specs that most CS cars run in autocross. Most tire shops won't install that btw, it's a lot of tire for not a lot of rim. Plenty of documentation about how CS cars are doing that a search will pull up.
MrBlaze-65 is offline   Reply With Quote
Old 05-06-2015, 02:00 PM   #5
AlexWood
Drives:
In my opinion, a 225 would be better suited. Also in my opinion, a 245 is way overkill for stock power. Just my 2 cents.
AlexWood is offline   Reply With Quote
Old 05-06-2015, 03:13 PM   #6
wparsons
wparsons's Avatar
215's on a 7" wheel, 225 at the absolute max. Going too wide on a narrow wheel will make it mushier, and doesn't give of crisp of steering feel.
If you want 245's, get 9" wide wheels.
flickr
WTB 17x7 wheel 15 lbs Iwannajag Want-To-Buy Requests 10 05-25-2015 08:59 AM
17x7 +25 Or Less Snake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 02-05-2013 06:46 AM
17x7.0 vs 7.5 G4mb17 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-14-2012 01:32 AM
Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 xravexboix Wheels and Tires 0 05-24-2012 08:04 PM
