17x7.0 vs 7.5
Looking for wheels, most of the ones I like at 7.5" (MR125), given I don't want to switch out the tires (yet), should I care? Will I notice this difference visually or dynamicly?
and when I do put new tires on, should I get 225s? Riki |
Pavement Grey
215's work on 7.5
Thats what i have on my car right now. PF01 17x7.5 +38 215/45/17 the 5x100 bolt pattern isnt available with the 17x7 which is why i have the 17x17.5 |
#3 | |
And did you move over the TPMS from the OEM wheels? |
Registered you sir
Drives: 99 impreza coupe
Why would you want to mount those junks back on anyway?
Figure they put them on there for a reason, and did lots of testing with them - so the least I can do is try them out for a while, to get an understanding of how it handles with their setup before I go changing to something more sticky.
Go with the wider wheel. The extra .5" will add grip, but not enough to make the car handle worse.
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
You'll be fine with the 7.5s as long as they aren't considerably heavier than the stock wheels. If they're lighter, even better. But a 215 can fit on a 7.5" rim no problem. You'll just notice a bit more stretch in the sidewall.
#8 | |
And when I do get new tires, would you say go to 225 or is this a non-issue? |
#10 | |
Corner Junkie
Check out this thread: http://www.ft86club.com/forums/showthread.php?t=8270 Even if you stick with 215s, if you move to a true summer Max or Extreme Performance tire, you'll gain width as well as grip without increasing diameter. |
#11 |
Hypnotic FRS Member
Drives: FR-S [Raven]
would it be 225/45/17 -- is that the next step up from stock ?
at what point do you change to 40's ? can someone explain the offset ? what are the stock offset ? thanks -- id love to change it soon also but im a bit lost about all the options. i would just want to do 1 or maybe 2 bumps up from stock -- what ever that is --- ??
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports- SoCAL |
#12 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Whatever tire size you go with, the goal is to keep the tire diameter as close to the original [which is 24.6" for the FR-S/BRZ] as possible, slightly smaller is better as is finding the lightest tire you can. If you don't choose carefully you could easily increase weight 5lbs a corner just from the tires. There's a nice sticky thread for wheel information if you haven't seen it: http://www.ft86club.com/forums/showthread.php?t=3062 |
| Wheel Directory: Velox VX-6R 17x7.0 +42 | jdrxb9 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-13-2013 12:35 PM |
| 17x7 RPF1s are coming!! | NYC BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 02-25-2013 09:06 PM |
| Buying OZ Superleggera 17x7 - Do I need hub rings? | NYC BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-10-2012 04:56 PM |
| Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 | xravexboix | Wheels and Tires | 0 | 05-24-2012 09:04 PM |
