Drives: 13 FR-S whiteout / blue w2w
WTB 17x7 wheel 15 lbs
My racing class (SCCA T4) only allows up to 15 labs and OEM size rims (17x7)
If you have any for sale or recommendations, please let me know. The closest I have come is 17 lbs Thanks |
Off Topic
I was going to say TWS, but they come in 17x8. I don't suppose you could argue that 16x7 is an OEM wheel size overseas, could you?
Or they might be able to be special ordered. Talk to @CSG Mike about it. http://counterspacegarage.com/produc...model=7&cat=18 edit The 17x8's come in at just under 14 lbs, so a 17x7 would be less. |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
That sucks, with the RPF1s coming in a 14.85lbs list weight. Maybe balance the wheel with 7 10 gram wheel weights to hit 15?
Off Topic
Is it UP to 15 lbs, or DOWN to 15 lbs?
edit Per the April GCR, T4 may go DOWN to 15 lbs. So TWS is out. Last edited by gramicci101; 04-01-2015 at 09:43 PM. |
Minimum weight is 15 lbs
Drives: 13 BRZ Limited, 2000 Impreza Sport
The way I read this, wheels under 15lbs would be considered illegal.
Innovate powered- Corn fed- FBM tuned
#7 | |
On the other hand, we can also intentionally make a wheel heavier to be *exactly* 15 lbs, but with the center of mass as close to the hub as possible to minimize rotational inertia. |
Custom made, that is good to know. I wasn't thinking that way. Is 2 lbs worth it to go custom?
Would RPF01 with balancing weights do the trick, like suggest before. It is listed as 14.85 lbs. |
Drives: 2013 Raven Scion FR-S
Have you looked through this list? http://www.ft86club.com/forums/showthread.php?t=11454
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
![]() RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T ![]() |
#10 |
Finally found some Touring 4 light wheels
Just posting in case someone else is researching.
Wedsport Leonis Navia 02. 15.3 lbs 17x7 Obtained via Touge Factory |
#11 |
Stiggasaurus Rex
Drives: '14 WRB Subaru BRZ 6MT
How much did they cost you?
meh.
| Wheel Directory: BBS RF 17x7.5 +48 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 112 | 11-02-2023 06:40 AM |
| Wheel Directory: BBS RK 17x7.0 +48 | Laika | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 64 | 05-21-2017 06:31 PM |
| Wheel Directory: XXR 521 17x7.0 +38 | ML | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 08-23-2015 09:26 PM |
| Wheel Directory: STR 601 17x7.5 +40 | Cross | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 01-06-2014 08:57 PM |
| Wheel Directory: BBS CF 17x7.5 +35 | elbles | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 12-02-2013 03:18 PM |
