Old 07-07-2013, 01:44 PM   #1
Tiz
Drives: Subaru BRZ
Appropriate tire size for 250-350 whp
Has anyone experience with a turbo kit and can recommend an appropriate tire size that provides sufficient traction?
I am wondering how far I will get with a staggered setup 225/45 R17 and 255/40 R17.
Many thanks.
Tiz is offline   Reply With Quote
Old 07-07-2013, 01:59 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
If straight line get wider rear. Handling a priority? Square 255, sticky tire
DD car? Best bet 245/265 stagger with a square set 255 or 265 for track use
Old 07-09-2013, 01:30 AM   #3
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
What suspension?
Old 07-09-2013, 10:03 AM   #4
Tiz
Drives: Subaru BRZ
KW v3+
car lowered by approximately 20mm
daily drive, only occasional track/auto x use
I heard many people saying that a 245 square setup or anything larger than 225 at the front will have a material impact on the car's turning ability. What would be the advantage of going wide at the front?
Thanks so much.
Old 07-09-2013, 10:18 AM   #5
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
The type of tire greatly dictates how wide you'll have to go.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 07-09-2013, 10:38 AM   #6
Tiz
Drives: Subaru BRZ
The idea is: Advan Neova AD08 225/45 R17 front, 255/40 R17 rear
Old 07-09-2013, 11:32 AM   #7
BlaineWasHere
Grip>Drift
Drives: FRS
Wider front tires means more front grip! I run 17x9 255/40/17 square and I don't eve have power mods. Why would you not want as much grip as possible? I'm also on KW V3.
Old 07-09-2013, 12:56 PM   #8
Tiz
Drives: Subaru BRZ
People say that the steering feels numb if the front tires are so wide. Moreover, factory cars like the Porsche Cayman do not use wide front tires. I am sure that there must be pros and cons related to a square setup. But unfortunately I do not really understand the effect of wide front tires.
Old 07-11-2013, 11:49 AM   #9
mrk1
Drives: Sterling BRZ Ltd
Real wide front tires can tramline more and can be more prone to hydro plane. Wider also means heavier and more money, generally. Im not discouraging wide square setups at all just mentioning a down side to consider.
I personnally love the look of huge tires but I also like a can that will move around a little and stay lively. Right now with stock power and stock tires I can drive as fast as I want on the street with out any over the top sliding at either end. Staying smooth is the key.
For the power range you suggested I would go for a 245 square with a good tire like a RE11A or AD08
just my .02
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-11-2013, 12:17 PM   #10
Tiz
Drives: Subaru BRZ
Thanks for the response.
What would be the advantages/disadvantages of a 245 square setup compared to the proposed staggered 225 front, 255 rear setup?
Acceleration should be better with the staggered setup. It should also feel more lively.
Do you expect significant understeer because of the smaller front tires and can't this be corrected with the help of the KW suspension and stabilizer bars?
Old 07-11-2013, 12:42 PM   #11
OrbitalEllipses
Drives: Attitude
Tire compound > contact patch IMO. Do you want more contact patch? Yes. But you want a stickier compound too.
Old 07-11-2013, 03:10 PM   #12
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i'm runing 265's all around. my steering is not numb by any means. i did most of hte bushings in the front though so i do have more feel than stock to begin with.
at the track the car was so neutral and i can still get the ass loose if i want if i really hammer on it but honestly i would be WOT and flat out through a lot of corners and the car was straight as an arrow.
in the end it depends how you drive, no tire will be able to keep you from getting sideways if you dont know what you're doing. however i wouldn't go smaller than a 255 in a good compound, unless all you wanna do is be sideways all day, or have to ***** foot the throttle.
Jive Turkey is offline   Reply With Quote
Old 07-11-2013, 04:18 PM   #13
mrk1
The rest of the suspension setup and alignment play a HUGE roll on how the car handles. Just adjusting tire pressures can make changes. Changing other suspension aspects change how tires contact the ground and how lateral force is managed. On stock tires I used to have a lot of interference from traction control (inside rear wheel spinning). Now with a number of tweaks I no longer get that interference on the same corners with the same stock tires. I get a kick out of reminding people Im still on "Prius" tires.
I run 265 Super Sports all the way around on my e46 M3 but thats a much heavier and more powerful car.
Ultimately its just like any other mod, pick what works for you.
The Build Thread
Old 07-12-2013, 02:40 PM   #14
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
This. x1000. You can not just simply choose a square or staggered setup. The entire suspension geometry comes in to play as well as springs rates and sway bars. I would recommend finding a race shop or racing team who does what you want to do, autox/roadrace/etc, but who's really really good. Check out they do, and copy that.
Stock cars with staggered tires come that way because the engineers set the car up for it. The same goes for square setups.
Acree is offline   Reply With Quote
Tire +/- size guide for FR-S/BRZ SpeedR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 12-11-2016 12:12 PM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 12:40 AM
225/35/18 Tire Size? stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-29-2013 08:09 PM
Which tire size for 17x8.5? giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-11-2013 07:26 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
