Old 04-28-2015, 02:40 PM   #1
Lebby83
Drives: 2019 BRZ, 2016 Touareg
Fog Light Removal/Replacement
Hey guys - So one of my fog light lenses broke the last time I had her at the track and instead of putting in a new one I have been thinking about removing both of them and making it look like the "premium" model.
Is that possible? Is it just a matter of ordering the OEM premium parts?
Thanks for any help.
rob
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
Old 04-28-2015, 02:42 PM   #2
swarb
yes. leave holes for brake ducts.
Old 04-28-2015, 02:45 PM   #3
Lebby83
I did think about that, but I am not at the point where I want to put them in yet, at least not until I put a BBK on her). Looking more for a temporary solution for now.
Rob
2016 VW Touareg TDI
Old 04-28-2015, 02:51 PM   #4
Lebby83
I found the part.... #21 on the diagram.
http://subaruparts.com/parts/2013/SU...&siteid=218240
Can someone confirm that it's just a simple swap between that one and the limited w/ fog lights?
Rob
2016 VW Touareg TDI
The Following User Says Thank You to Lebby83 For This Useful Post:
Choco (04-28-2015)
Old 04-28-2015, 03:08 PM   #5
adamg
Drives: brz
Yup i did this mod a couple months ago. each side is like $10 and takes like 30 min total to remove fogs and install these
adamg is offline   Reply With Quote
Old 04-28-2015, 03:20 PM   #6
Lebby83
Thanks. Glad to know it's only a 30 minute job. Anything I should look out for while doing it, or is it pretty simple?
Rob
2016 VW Touareg TDI
Old 04-28-2015, 03:37 PM   #7
adamg
Drives: brz
just remove a couple screws from the fender liner so your able to pull it back enough to remove the 2 screws behind your DRL leds. Once those bolts are out you can pull out the DRL leds, fog lights and fog light housing. unplug the fogs. separate your DRL from the fog light housing. Then connect your DRL to your new housings. Install them back into your bumper, screw in those two bolts to the back of the DRLs, and then screw in the fender liner bolts.
now repeat on other side and your done.
Enjoy the clean look of a fog-less bumper
The Following User Says Thank You to adamg For This Useful Post:
pinski (04-28-2015)
Old 04-28-2015, 03:49 PM   #8
Lebby83
Thanks. Appreciate it!
Rob
2016 VW Touareg TDI
Old 04-28-2015, 04:00 PM   #9
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
I've been considering this as well - thanks for the walkthrough!
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
Old 09-24-2016, 11:07 PM   #10
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Does the car throw a bulb light on the dash after removing the fogs?
Old 09-28-2016, 11:29 AM   #11
norcalpb
norcalpb's Avatar
It's a Subaru...no.
The Following User Says Thank You to norcalpb For This Useful Post:
Yoshoobaroo (09-28-2016)
DIY Request: Axle Removal/Replacement xjohnx DIY (Do-It-Yourself) Guides 10 09-22-2016 06:30 PM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
BRZ fog light removal for tint. how? chenshuo BRZ First-Gen (2012+) — General Topics 10 03-27-2015 09:03 AM
BRZ fog light bezel removal ucsmfu BRZ First-Gen (2012+) — General Topics 3 09-23-2014 01:38 AM
Airbag light stays on after removal/reinstallation Pablitomarrero Issues | Warranty | Recalls / TSB 13 04-04-2014 08:34 AM
