Old 09-22-2014, 12:47 PM   #1
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
BRZ fog light bezel removal
Anyone know how to remove it ?
Does the bumper need to come off ? or can it be done by just going through the side fender liner ?
Thanks
ucsmfu is offline   Reply With Quote
Old 09-22-2014, 02:49 PM   #2
Lebby83
Drives: 2019 BRZ, 2016 Touareg
You can get to it from inside the fender liner.
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
Old 09-22-2014, 03:03 PM   #3
tobin
tobin's Avatar
Drives: '13 BRZ
Follow the owner's manual for changing fog bulbs. Remove the tree clips in the fender liner, and two on the bottom (gives you a little more room to work with). Pull the liner back and you will see the fog assembly. There are only 2 screws holding it in place. Remove those and you can slide the part out through the fender liner.
tobin is offline   Reply With Quote
Old 09-23-2014, 01:38 AM   #4
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Will I have to remove the DRL leds first ?
Thanks
Searching for fog light bezel idover Cosmetic Modification (Interior/Exterior/Lighting) 1 03-11-2022 09:39 AM
Shifter bezel removal question BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 2 08-08-2014 11:17 AM
FS: Oem fog light/bezel nguyen_er Exterior Parts (Aero, Lighting, Etc.) 8 09-18-2013 05:01 PM
New DRL fog light bezel thingy SkAsphalt Cosmetic Modification (Interior/Exterior/Lighting) 10 08-27-2013 03:46 PM
Gap between Fog light & Bezel FIX PineappleFriedRice Cosmetic Modification (Interior/Exterior/Lighting) 11 08-13-2013 06:20 AM
