Old 04-25-2015, 02:35 PM   #1
wootwoot
Drives: FRS
Turn signal camera?
I just got done installing a back up camera in my car. Like it a lot!
Would it be possible to set up two small backup cameras in each rear side-window to turn on with your blinkers and display on your head unit? The idea being to assist with lane changes. I have a hard time seeing in my car. Thought it would be a fun project. Ideas?
wootwoot is offline   Reply With Quote
Old 04-25-2015, 03:06 PM   #2
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
It's possible, but you would need an android head unit with an app that allows that. EDITS: I would also work the cameras into the side mirrors somehow for a better viewing angle as opposed to out the rear window.
On the other hand. I would say don't do it and instead get some convex mirrors and point them outwards to where your blind spots are. Looking at a stereo unit instead of out the window when changing direction is imo bad driving practice's.
But I'm also the guy who uses the mirror setup I described above, so I no longer look over my shoulders anymore, I'm bias. Stupid massive B-pillars.
jimmillion is offline   Reply With Quote
Old 04-25-2015, 03:13 PM   #3
wootwoot
Drives: FRS
Interesting.... I wouldn't only look at my stereo to change lanes... Lol
You couldn't wire up a board to switch between inputs and use the factory head unit?
Old 04-25-2015, 03:20 PM   #4
jimmillion
Power Ranger Elite
jimmillion's Avatar
A logic board would definitely allow you to switch inputs between cameras depending in which signal it gets , ie. Reverse trigger vs. Turn signal.
But the problem with the factory head unit is that it only has the ability to display one camera at a time as far as I'm aware. You would have to make software changes to get it to show spilt screen camera feeds for you new dual turn signal feeds
Old 04-27-2015, 12:21 AM   #5
wootwoot
Drives: FRS
Why would you need multiple cameras?
Reverse=reverse cam on trunk
Left blinker=camera on left rear window
Right blinker=camera on right rear window
Where would I go to ask about making a board like that? I don't think I could figure it out....
Old 04-27-2015, 12:41 AM   #6
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
4 camera interface.. http://www.aliexpress.com/item/4-Cam...763979586.html
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 04-27-2015, 02:06 AM   #7
CoupedUpSubie
Drives: 2013 BRZ Limited
Biggest issue will be triggering the head unit to display the camera feed from each camera. I would think running the turn signal command for each side so it activates the display in the same manner the reverse sensor does should work. Finding what that signal is and the wire it needs to go to would be key. The turn signal circuit would also have to be the signal to turn on the camera. It would be a mess of wires.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 04-27-2015, 10:08 AM   #8
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
Not to troll, but wide angle mirrors do a great job at increasing visibility. Although, more power to you if you go the camera route.
eggncheese is offline   Reply With Quote
Old 04-27-2015, 12:40 PM   #9
jimmillion
Power Ranger Elite
jimmillion's Avatar
Oops my bad. You're right, you would only need to show one camera at a time on screen. So no software modifcations to the head unit would be needed.
I think buying that camera module from aliexpress would be the best way of doing it. Building one of your own would be quite the headache if you don't know what you're doing. And having one custom made would probably be more then 50 dollars.
Old 05-16-2015, 03:47 AM   #10
chubky
chubky's Avatar
Drives: 2014 Scion FR-S Monogram
I concur. I got them a few months back. It's worth it, although I still turn my head to check even though there are no blind spots at all.
chubky is offline   Reply With Quote
Turn Signal in OEM DRL/HiBeam? 636 Cosmetic Modification (Interior/Exterior/Lighting) 8 03-24-2015 04:46 PM
Turn signal question OMGreta Cosmetic Modification (Interior/Exterior/Lighting) 6 01-27-2014 02:06 PM
WTB FR-S Turn Signal Lights retrosmiths Want-To-Buy Requests 2 01-08-2014 02:13 PM
Turn signal issue Asphaltfrs1 Issues | Warranty | Recalls / TSB 3 06-21-2013 06:06 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
