Old 06-19-2013, 11:15 PM   #1
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
Turn signal issue
Just noticed that my passenger side turn signal doesn't light up. It works as far as blinking but it doesn't light up with the headlights. Would it be a fuse?
Any help would be appreciated, thanks in advance.
Asphaltfrs1 is offline   Reply With Quote
Old 06-21-2013, 05:29 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
Do you have leds ?
mashal is offline   Reply With Quote
Old 06-21-2013, 06:04 PM   #3
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
LEDs would not cause this, I have LED's on my side markers and they light up -- My wiring is also bone stock.
CamryDS is offline   Reply With Quote
Old 06-21-2013, 06:06 PM   #4
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
Are you talking about the front turn signal? Is it stock?
If so, that's a dual filament bulb. You probably just have a burnt out bulb... Or at least the running light filament is burnt out.
Narcoden is offline   Reply With Quote
LED TURN SIGNAL BULB myjobis2pimp NY / NJ / CT / PA 1 12-10-2013 06:28 AM
Does 6k HID's Go well With the Turn Signal Switchbacks J-Money Cosmetic Modification (Interior/Exterior/Lighting) 17 01-29-2013 10:41 PM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
