Old 03-24-2015, 10:02 AM   #1
636
636's Avatar
Drives: '23 CWP BRZ
Turn Signal in OEM DRL/HiBeam?
I've got an idea, but I'm not too sure it would work.
Do you think it'd be possible to buy an amber bulb/led, and replace the DRL/HiBeam in the OEM headlight with it, run a wire from it down to the turn signal, and splice it in?
Therefore creating a turn signal in the headlight. Obviously this would be for a non Monogram/10Series/RS1.0 FRS.
636 is offline   Reply With Quote
Old 03-24-2015, 10:47 AM   #2
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
I think it'd be possible, but then you lose your high beams, but it will make your car even more unique
KungFuWaffle is offline   Reply With Quote
Old 03-24-2015, 11:01 AM   #3
Koa
Would be nice to have that in a swichback setup. I use LED DRLs and their hi-beam function is already gone. If it mirrored the switchback behavior down on the lower running lights/turns, that would be so dope.
Will ping DD about it
Old 03-24-2015, 11:32 AM   #4
636
636's Avatar
Drives: '23 CWP BRZ
Keep me updated on it.
Old 03-24-2015, 01:13 PM   #5
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
(dumb question) is there a thread somewhere or discussion that shows a picture of the front of the car, that points out what the stock function of each lamp is, and where it's located... for all the variants of the twins over time?
For stock standard editions, and also the Monogram/10Series/RS1.0 FRS.
And if the locations have changed over time, or some countries have additional markers or lamps, pointing those out as well.
TapTurn flasher learn more here.
scottmcphee is offline   Reply With Quote
Old 03-24-2015, 01:46 PM   #6
8R6
8R6's Avatar
Drives: FRS
why not just convert to BRZ headlights? oem quality, turn signal in the same place, oem xenons, led drl integrated already.
8R6 is offline   Reply With Quote
Old 03-24-2015, 02:08 PM   #7
636
636's Avatar
Drives: '23 CWP BRZ
My current headlights are Bi-Xenon, LED DRL, Sequential Turn Signals, but I'm just trying to do something with OEM FRS lights. I love BRZ lights, but for how expensive they are..I'll pass.
Old 03-24-2015, 02:24 PM   #8
8R6
8R6's Avatar
Drives: FRS
oh yeah i forgot. yours are modded frs lights already
Old 03-24-2015, 04:46 PM   #9
Koa
because $$$$$$$$$$$$$$$$$$$$$$$
Disable Turn Signal DRL? 636 Cosmetic Modification (Interior/Exterior/Lighting) 10 09-14-2014 08:09 AM
FRS turn signal mods subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 19 03-07-2014 01:34 AM
LED TURN SIGNAL BULB myjobis2pimp NY / NJ / CT / PA 1 12-10-2013 06:28 AM
LED Turn Signal Issue FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 15 07-23-2013 12:47 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
