Old 04-23-2015, 06:13 PM   #1
Tal
Tal's Avatar
Drives: Scion FRS 10 Series
Tire Pressure.
Alright guys, I have a very important question. At what PSI should I run my new tires at.
Specs -
Wheel size: 18x8.75
Tire size: 245/35/18 Michelin Pilot Sport A/S 3.
Currently running at 35psi, and was wondering if 40psi would be better?
10 Series Owner. Love it.
Tal is offline   Reply With Quote
Old 04-23-2015, 06:59 PM   #2
wparsons
wparsons's Avatar
What exactly are you trying to make better?
flickr
Old 04-24-2015, 12:09 AM   #3
Tal
Tal's Avatar
I want a stiff ride, with good traction and less wear and tear
Old 04-24-2015, 12:23 AM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Tal View Post
I want a stiff ride ((then more psi)) with good traction and less wear and tear ((then less psi))
Theres a fine line between good grip and overly pressurized sidewalls.
Old 04-24-2015, 12:49 AM   #5
ryoma
ryoma's Avatar
I usually fill all my tires at 32 cold. that usually brings it up to about 36ish hot. I let it drop until 30 cold before I refill them again. though, I always check every week to make sure the pressure is even on all 4 tires.
Old 04-24-2015, 12:10 PM   #6
wparsons
wparsons's Avatar
There's no magic bullet. If you want to optimize grip and wear, you'll need to be monitoring the tires more closely to see what they need.
If pressure is too high, you'll see warmer temps (and more wear) in the center of the tread, too low of pressure and you'll see warmer temps (and more wear) on the outer edges of the tread.
By the sound of it, just stick with 35psi and stop over thinking it.
flickr
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Tire Pressure for PSS? Pacific Auto Tracking / Autocross / HPDE / Drifting 12 01-22-2014 10:50 PM
tire pressure mrnibbs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2013 10:09 AM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 05:47 AM
