Old 01-22-2014, 12:35 AM   #1
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
Tire Pressure for PSS?
I am terrible at finding a setting for my 17/45R/225 PSS on stock wheels.
What would you recommend for Front/Rear PSI hot?
Pacific Auto is offline   Reply With Quote
Old 01-22-2014, 12:57 AM   #2
diss7
Drives: AE86, 2x GT86, TE27
Aim for 30 psi hot.
Its a good starting point.
Once you get to the point of really 'feeling' the car, try a few psi more or less, and see if you like it.
diss7 is offline   Reply With Quote
Old 01-22-2014, 01:17 AM   #3
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
I like mine at 36 psi hot both F/R for OEM suspension
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 01-22-2014, 01:34 AM   #4
Pacific Auto
Master Installer
Drives: Scion FRS
Originally Posted by diss7 View Post
Aim for 30 psi hot.
Really?... I have been trying 36, 38, 40 hot!
Old 01-22-2014, 01:36 AM   #5
Pacific Auto
Master Installer
Drives: Scion FRS
Ok, would coilovers need less or more psi? I am running Bilstiens B14's. I just bought HVT camber plates since I still have understeer.
Old 01-22-2014, 01:41 AM   #6
RehabJeff86
If ur car is understeering with coilover, try 34 psi front and 36 psi rear or go for adjustable sway bars to correct understeer, typically make rear sway stiffer to induce oversteer
Old 01-22-2014, 02:18 PM   #7
dsgerbc
Drives: BRZ(sold), STI
How much camber are you running?
dsgerbc is offline   Reply With Quote
Old 01-22-2014, 02:57 PM   #8
Pacific Auto
Master Installer
Drives: Scion FRS
Front Driver: Front Passenger:
Camber: -1 9/16 -1 3/16
Caster: +5 7/16 +5 7/16
Lowered: 1" 1"
Toe: 0
Rear Driver: Rear Passenger:
Camber: -2 1/4 -2 1/8
Toe: In 1/16"
Lowered: 3/4" 1"
Plan is to bump the front chamber to -2 1/2 with the HVT plates.
Old 01-22-2014, 03:21 PM   #9
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I think a good question is, what is the car doing that you don't like?
Ranatsu is offline   Reply With Quote
Old 01-22-2014, 03:51 PM   #10
CSG David
CSG David's Avatar
Fix the alignment. If you're on track when we're out there, don't hesitate to get in touch with @CSG Mike.
On a super side note, I'm going contact you regarding that 3M Clear Bra stuff.
Old 01-22-2014, 06:55 PM   #11
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
You'll probably have to run a bit higher PSI if you are looking to get the most life out of them. I typically run 36psi hot, but the shoulders of mine are corded now.
Honestly, I really dont like the MPSS at all on track. They were a vast improvement over stock, and were good for the first two events, but by the 3rd track event I noticed horrible shoulder wear with my camber maxed out on stock suspension with the whiteline camber bolts (around -1.6* up front), and the tires just had no grip anymore. After 5 track events (8 track days total - 2 of them on the coilovers with -2* camber) with really no street driving, the shoulders on the MPSS are corded, and have no grip whatsoever.
I'm running RS3's next.
Sorry for the off topic rant, lol.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 01-22-2014, 07:09 PM   #12
CSG David
CSG David's Avatar
Need moar camber!
Old 01-22-2014, 10:50 PM   #13
smbstyle
smbstyle's Avatar
Originally Posted by CSG David View Post
Need moar camber!
Gah I know, camber plates are next. add it to the to-do list!
2013 SWP BRZ
tire pressure mrnibbs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2013 10:09 AM
Tire Pressure Fallen43 CANADA 2 10-12-2013 12:46 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 05:47 AM
Tire pressure of all-seasons Scoob Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 11-12-2012 12:49 AM
