Old 04-21-2015, 03:38 PM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
For those that run the Togue Factory brake duct kit...
1. What kind of pads are you running?
2. What kind of tires are you running?
3. What kind of fluid are you running?
4. Have you been able to boil your brake fluid, even a little bit, on track?
I had my first track weekend with the TF kit recently. After putting my street pads back in it feels like the pedal is a little soft. It may just be in my mind, but I'm curious to hear if anyone has gotten air in their lines will running the duct kit.
FWIW, I'm using DTC-60s with HTRZ-IIIs and RBF-600.
Old 04-21-2015, 03:50 PM   #2
swarb
Sounds like street pads or brake fluid needs a quick bleed.
Old 04-21-2015, 04:20 PM   #3
Two things.
1. you got used to the bite of the DTC60
2. your street pads and rotors are not properly mated or bedded. The surface grooves dont match (no mating) and th ebedding layer is from a different pad.
It'll get better as you drive it, but now you know why I permanently keep track pads on my car.
Old 04-21-2015, 04:30 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
Two things.
I think that's probably the case, but am interested in hearing others' setups and experiences, too. I've noticed this previously after other events, but I don't remember it being to this degree. Thanks for the response, Mike.
Oh, and I live in Denver, drive 20,000+ miles per year, ski a lot and use this as my only car. Unfortunately some of the solutions you guys implement (track pads all the time, etc.) just don't work for my situation. I wish they did, though. It sure would make things easier.
Old 04-21-2015, 04:32 PM   #5
Well, the easiest fix is to just bleed the brakes first; fluid is relatively inexpensive.
As strange as it sounds, I actually have a decent amount of experience with cold weather and snow... I also ski patrolled in my spare time
Old 04-21-2015, 04:43 PM   #6
Pat
Pat's Avatar
Drives: 2023 BRZ
Yeah, bleeding is a cinch. I wonder if I really have air in the lines, though. Not that it's a big deal to bleed an not need it. But why do it if it's unnecessary, right?
Your comment about patrolling...did I say something about doing it in the past? What mountain were you at? I was at Loveland for several years.
Old 05-07-2015, 05:13 PM   #7
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Carbotech XP10/XP8
Bridgestone Potenza RE-71R
Motul RBF600
No. I did, however, melt the Carbotech XP10 pads and smear them all over the rotor at Road America
Apex_BRZ is offline   Reply With Quote
The Following User Says Thank You to Apex_BRZ For This Useful Post:
Pat (05-07-2015)
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Is there an FRP/urethane brake duct out there? Blizzard Cosmetic Modification (Interior/Exterior/Lighting) 4 12-10-2013 10:31 AM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
