Old 04-09-2015, 07:30 PM   #1
swarb
Lightbulb Alignment: Car wanders slightly with zero toe up front.
So I got an alignment.
camber 2.9 front 2.7 rear
.08 toe rear
0 toe front
everything was the same on both sides except for caster.
caster left 5.5 caster right 6.3
Car seems to wander slightly and mostly right.
I am thinking it could be the 0 toe or the cap on the road that makes rain water pool to the outside of the road. Or possibly the caster?
Normal?
How much toe is .08(degrees?) equal to? 1/32? 1/16?
does front toe out during compression? (because i was toe'd out before alignment)
does rear toe in during compression? (because i was toe'd in before alignment)
factory stock height measurement? from fender to center of wheel or from fender to ground?
Old 04-10-2015, 11:11 AM   #2
bfrank1972
Drives: 2013 FR-S Argento
.08 toe rear
0 toe front
Normal?
does front toe out during compression? (because i was toe'd out before alignment)w
Possibly, uneven caster can cause the car to wander in one direction or the other. Also might be exacerbated by the significant front camber.
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
swarb (04-10-2015)
Old 04-10-2015, 11:38 AM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
are your tire pressures equal?
The Following User Says Thank You to 7thgear For This Useful Post:
swarb (04-10-2015)
Old 04-10-2015, 12:20 PM   #4
mrk1
Drives: Sterling BRZ Ltd
Crown in the road, pretty typical to see a wonder to the right If your looking for it.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
swarb (04-10-2015)
Old 04-10-2015, 12:44 PM   #5
swarb
Yes pressures are equal. I checked before alignment and the alignment guy checked also. They are a little high at 40psi cold. Slightly stretched 225/40-18 federal 595ss which run wide, on a 9.5 wheel. I will try 36-38psi and see how that works.
Old 04-10-2015, 04:08 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
federal 595ss
Your tires are contributing to the "wandering", and your camber is exaggerating any crown in the road.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Hyper4mance2k (04-10-2015)
Old 04-10-2015, 04:17 PM   #7
swarb
-alex
because they are stretched? or because they are low quality/budget tires?
Old 04-10-2015, 04:25 PM   #8
mav1178
mav1178's Avatar
Because of the tread design. I used to have the same tires on a completely stock S13 (205/55-15) and with no other changes, the car was more prone to track/wander on road surfaces.
If you want to be truly scientific about it, you have to replicate the same driving on the same roads with different tires.
-alex
swarb (04-10-2015)
Old 04-10-2015, 05:27 PM   #9
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Both. The stretch exacerbates camber, plus directional tire tread designs are notorious for wonder on the road crown.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-12-2015, 04:34 AM   #10
WRKHARD
Drives: 13' FRS
rear toe on these cars can result in pull. snag some rear toe arms and have the alignment shop straighten the rear out
WRKHARD is offline   Reply With Quote
Old 04-12-2015, 04:52 AM   #11
swarb
It has positive toe in the rear. Aka toe in. Which is would not cause this slight problem. Negative toe aka toe out would though, which I don't have.
It is probably from the tires, So I am going to rotate wheels front for rears and double check the pressures and drop a couple pounds to 36-38 from 40, and see how that works.
FS: slightly used OEM FRS front BUMPER w/ Lip JonMotoring Exterior Parts (Aero, Lighting, Etc.) 31 08-07-2014 03:21 PM
Front bumper alignment TheGuyWithTheFireStorm Northern California 5 04-21-2014 02:10 AM
Front Camber Bolts / Alignment Question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-17-2013 04:31 AM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Front alignment woes empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-12-2013 12:56 PM
