Old 06-03-2013, 06:55 PM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Thumbs down Front alignment woes
Here's the situation .. I have my car on HSD coilovers with camber plates as well as whiteline KCA416 16mm upper camber bolts.
The car is not very low, no hellaflush action and I CANNOT get more than -2.0 camber in the front. I need 2.5 badly. It seems I am running out of options. The camber plates and the bolts are MAXED.
Anyone had any better luck? The rear is almost no better but I got the desired alignment with my Cusco LCA's.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 06-03-2013, 07:01 PM   #2
@robispec can help if you want to keep your current ride height.
Have you considered lowering more? You'll get more camber (to a degree).
We had no problem hitting -3 with our Tein SRCs, and we still have room to get more.
Old 06-03-2013, 07:01 PM   #3
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
New coilovers?
I run stance and get about -4 degrees camber and I can still move the two inner Allen bolts in further for more
TylerLieberman is offline   Reply With Quote
Old 06-03-2013, 07:04 PM   #4
empower-auto
Kouki-Monster
I can go lower but I do not want to. I am losing too much suspension travel then, and the wheel will probably hit the inner fender when auto-crossing.
Rich Anderson
EMPOWER AUTO
Old 06-03-2013, 07:09 PM   #5
Are your camber plates installed on the correct sides? How much are you dropped?
The bolts alone should already have you at more than -1
Old 06-03-2013, 07:14 PM   #6
Racecomp Engineering
My guess is your plates are on backwards like the other guy. He had HSDs as well...maybe they're marked incorrectly? Can you take a pic?
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
CSG Mike (06-03-2013)
Old 06-03-2013, 08:26 PM   #7
derek1ee
Drives: BRZ/FRS/STI/M3
not try to bring this off topic but is there a different between left/right the stock top hat? What about the orientation of the stock hat (red dot facing some direction?)
derek1ee is offline   Reply With Quote
Old 06-04-2013, 01:35 PM   #8
empower-auto
Kouki-Monster
plates are on properly as far as I can see
Rich Anderson
EMPOWER AUTO
Old 06-04-2013, 01:54 PM   #9
DragynVyrus
Drives: FRS, MR2
If I remember correctly(99% sure I just haven't looked myself yet) the fronts are Mac style struts right? If so you can get rid of the camber bolt and slot the top hole on the strut that bolts to the knuckle and reinstall the stock bolt. Bit more labour intensive and a bit more of a pain to set up but it works. Just another option if you are correct and everything is installed right.
DragynVyrus is offline   Reply With Quote
The Following User Says Thank You to DragynVyrus For This Useful Post:
SMOKETREES (06-07-2013)
Old 06-04-2013, 02:09 PM   #10
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I agree with the folks that think something is fishy here. I've got stock springs and struts in front, but use two camber bolts per side (OEM in the top hole, SPC in the bottom) and have about -2.3 degrees.
No camber plates or lowering needed.
celica73 is offline   Reply With Quote
Old 06-04-2013, 02:13 PM   #11
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Just take some pics of your camber plates and post them up
GTM_Challenge is offline   Reply With Quote
Old 06-04-2013, 05:33 PM   #12
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
i got to -1.4 on bolts alone (dialed it back to -1.1) and i'm only lowered 1.4 inches. to think that camber plates can only get another 0.6 doesn't seem right at all...
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 06-04-2013, 07:39 PM   #13
empower-auto
Kouki-Monster
will toss up some pics tonight
Rich Anderson
EMPOWER AUTO
Old 06-05-2013, 11:07 AM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Pics look good. I am also convinced you reversed the install of the camber plates as another person did.
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Clear bra install woes - Is it that hard? SHIFTER Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 31 05-12-2013 10:48 PM
Financial woes have me thinking about a trade JoeBoxer Other Vehicles & General Automotive Discussions 16 02-10-2013 02:47 PM
Bolt Pattern Woes TSLRich Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-29-2012 11:30 PM
Pre-Order Disappointment woes Draco233 BRZ First-Gen (2012+) — General Topics 16 03-03-2012 04:31 PM
