Northern California NorCal
Old 04-15-2014, 08:39 PM   #1
TheGuyWithTheFireStorm
Drives: FireStorm MT FRS
Front bumper alignment
Whats up, sunday afternoon I was driving on the freeway and an older suburban ran over a scrap piece of tire that got kicked up and hit my front bumper. No cracks, no dents, no scratches. The only thing i noticed different about my FRS is there is a tiny gap between the bottom corner of one of the headlights. Anybody in the bay area have any experience removing the front bumper? Or have any suggestions on how I should tackle this situation. Thanks for your input. Will try and include a picture.
TheGuyWithTheFireStorm is offline   Reply With Quote
Old 04-16-2014, 03:41 AM   #2
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
in the DIY section here there are a number of threads detailing how to do this. you can also go to youtube and just search Winjet headlight installation for the FRS and there are also a bunch of how to videos for this car as well.
hope this helps, good luck
"Power is nothing without Control"
j2digit is offline   Reply With Quote
Old 04-16-2014, 10:54 AM   #3
Bach415
Bach415's Avatar
Drives: Whiteout FRS
^that. It's pretty straight forward removing the bumper. Only issue you most likely will have is getting the side markers off(hard to get off the first time) and putting it back on(doesn't look as flush as it was before)
Bach415 is offline   Reply With Quote
Old 04-17-2014, 05:00 PM   #4
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
if even after you remove the bumper and put it back on and it doesn't align right then you may need to go an extra step and kind of reinstall/realign the bracket that holds the bumper in as well. I had a similar problem after i rear-ended someone. i got the bumper replaced completely, but i still had the gap until i pulled it off and messed with the bracket.
phanguy is offline   Reply With Quote
Old 04-17-2014, 05:47 PM   #5
mystic
mystic's Avatar
Drives: 2020 BRZ PP CWP
yeah, once you take it off it just never sits the same I suppose. My sidemarkers are a little wobbly and loose after I took off my bumper, but the removal is quite easy. The DIY should get you through it (see below for links), the hardest part like @Bach415 said is taking off your sidemarkers. Do your best to stay patient lol
Here is the thread I followed to get my bumper off. You will only go up to step 8.
http://scionfr-s.blogspot.com/p/fron...r-removal.html
Also here's a secondary link that pays more attention to the sidemarkers, this was useful as well when I got stuck on how to take them off.
mystic is offline   Reply With Quote
Old 04-21-2014, 02:10 AM   #6
Thanks guys!
FRS Bumper alignment issue, help please Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 5 06-04-2015 02:27 PM
WTB: Raven front bumper plus front underpanel and passenger side front fender liner THEmailman Want-To-Buy Requests 1 04-20-2014 12:05 AM
Wtt: green brz front bumper for any frs front bumper Guildjs Exterior Parts (Aero, Lighting, Etc.) 46 04-02-2014 12:12 PM
Swap my BRZ front bumper for your FR-S bumper (GBS/ultramarine) wulfgang Exterior Parts (Aero, Lighting, Etc.) 8 11-26-2013 06:48 PM
Front alignment woes empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-12-2013 12:56 PM
