Drives: 2013 Subaru BRZ Sport Tech
Vehicle Speed Sensor Location or Pin Out
Hello everyone, can someone tell me where the VSS wire is located on the car?
I am trying to tap into vehicle speed signal for the TEIN EDFC. Any help would be appreciated, thanks.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
#2 |
Drives: Subaru BRZ
@jjkerr626 were you able to find the VSS location to tap for EDFC? I'm curious as well (sorry to revive old thread but I've searched online and no luck)
#3 |
Drives: 2005 Toyota Camry
#4 | |
Drives: Subaru BRZ
#5 |
Drives:
sorry to bring up an old topic, i'm trying to do the same thing with my edfc active pro, i was just wondering which wire did you end up connect to in your vehicle
#6 |
Drives: 2JZ FRS
wheel speeds are canbus through the abs module
#7 |
Drives:
I finally found the answer from an old topic post by kothetimeless the diagram below should help
![]() Vss cable is #17 Work with EDFC active pro Sent from my iPhone using Tapatalk |
| DOT Proposes Mandating Cars Broadcast Location, Direction and Speed | Tromatic | Other Vehicles & General Automotive Discussions | 27 | 08-28-2014 08:27 PM |
| Eng coolant temp sensor location | D K | Engine, Exhaust, Transmission | 28 | 08-27-2014 05:30 PM |
| Boost Up Your Vehicle's Speed, Power, & Track Times at FR Sport! | FRSport.com | Forced Induction | 0 | 01-24-2014 12:33 PM |
| OEM Oil Temp Sensor Location | Khorne | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 01-15-2014 10:38 PM |
| Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
