Old 04-01-2015, 03:55 AM   #1
HachiEnam
UCSB!!!
HachiEnam's Avatar
Drives: 2017 GTI sport
Running RX-7 Wheels
If I want to run stock FD rx7 rims, will I need a spacer? They are 16x8 and weight 15 lbs with an offset of 50mm. Sorry I do not know much about wheels.
HachiEnam is offline   Reply With Quote
Old 04-01-2015, 02:51 PM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Wrong bolt pattern. Your car is 5x100 (five bolts on a 100mm circle) but the RX-7 and most other Japanese sports/luxury cars are 5x114.3.
You would need a spacer/adapter to change the bolt pattern.
Old 04-01-2015, 02:59 PM   #3
shifter907
Lurker
shifter907's Avatar
Drives: '14 BRZ Ltd 6MT
Originally Posted by DarrenDriven View Post
Wrong bolt pattern. Your car is 5x100 (five bolts on a 100mm circle) but the RX-7 and most other Japanese sports/luxury cars are 5x114.7.
5x114.3*
Instagram : @brampbell_candon
Facebook : Hipster Vision Photography
shifter907 is offline   Reply With Quote
Old 04-07-2015, 06:33 PM   #4
HachiEnam
UCSB!!!
HachiEnam's Avatar
Thank you guys for replying!
Old 09-08-2015, 11:43 AM   #5
DarrenDriven
NW Region Moderator
Originally Posted by shifter907 View Post
5x114.3*
Not sure if I had a brain fart or a finger fart, but yes, that is correct. Oops!
Old 09-09-2015, 01:04 PM   #6
jumbaco
jumbaco's Avatar
Drives: FD
There are two versions of the wheel just FYI. There's a reinforced version that's a little heavier.
Reinforced version on the right.
jumbaco is offline   Reply With Quote
Old 09-10-2015, 03:40 PM   #7
HachiEnam
UCSB!!!
HachiEnam's Avatar
Thanks . But this post was from 5 months ago and I got a set already.
Essex/AP Racing BBK Owners- What wheels are you running? JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 170 04-15-2025 02:48 PM
For anyone running Forgestar F14 wheels empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-10-2014 11:52 PM
Anyone running 245/45R16 on 16x8 wheels? stockysnail Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-03-2014 11:15 PM
Running 2011-12 STI Limited wheels possible? brzadmir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-31-2013 05:19 PM
What size wheels do you plan on running? poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 04-28-2012 05:30 PM
