CANADA Canada
Old 03-30-2015, 04:39 PM   #1
sixthree
Drives: 14BRZ
Best shop in Toronto to get an alignment?
Anyone know where the best place to get an alignment in Toronto is? Preferably in markham/scarborough.
sixthree is offline   Reply With Quote
Old 03-30-2015, 04:40 PM   #2
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
I second this
bhbnuckle is offline   Reply With Quote
Old 03-30-2015, 08:07 PM   #3
df.dima
Drives: FR-S and Mazda 3 Sky
http://www.ft86club.com/forums/showthread.php?t=53151
http://www.ft86club.com/forums/showthread.php?t=53695
df.dima is offline   Reply With Quote
The Following User Says Thank You to df.dima For This Useful Post:
drewbot (03-31-2015)
Old 03-30-2015, 10:51 PM   #4
BRZ'13
BRZ'13's Avatar
Drives: subaru
Scott at can-alignment. well worth the drive, won't find a better place
BRZ'13 is offline   Reply With Quote
The Following User Says Thank You to BRZ'13 For This Useful Post:
Burrcold (03-30-2015)
Old 03-30-2015, 10:53 PM   #5
congee
congee's Avatar
Drives: SSM BRZ
Also looking into this, how much do they usually go for??
congee is offline   Reply With Quote
Old 03-30-2015, 11:16 PM   #6
Burrcold
Drives: Subaru BRZ Limited
Yup Scott is a wizard!
Old 03-30-2015, 11:41 PM   #7
BRZ'13
BRZ'13's Avatar
Drives: subaru
costed me $325 for corner balance and alignment
Well worth to get both done If your tracking the car
congee (03-30-2015)
Old 03-31-2015, 12:20 PM   #8
wparsons
wparsons's Avatar
Alignment alone should be about $150ish from Scott. Well worth the drive though. He has a ton of racing experience and can not only set your alignment, but give insight into what specs you'll want.
flickr
Old 04-27-2015, 03:37 AM   #9
AnsonFrs
AnsonFrs's Avatar
Drives: 2013 Whiteout FRS
i got my FRS done at K.S.L auto shop alignment and tire rotation for $80! i highly recommended! he didn't rush at all and took his time!
AnsonFrs is offline   Reply With Quote
Old 04-27-2015, 12:02 PM   #10
wparsons
wparsons's Avatar
What are the final specs at each wheel?
flickr
Old 04-27-2015, 12:44 PM   #11
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
I couldn't find a time that worked for me and Can-alignment, so I ended up going to NV Auto in Stoney Creek.
$110 for the alignment, they were able to dial this in pretty quickly (print out is at home):
FRONTS (L/R):
Camber: -2.1/-2.0
Caster: 6.3 (untouched, but my strut tops can adjust)
Toe: 0.02 / 0.0
REAR (L/R):
Camber: -2.0/-2.0
Toe: 0.10 / 0.09
drewbot is offline   Reply With Quote
Old 04-27-2015, 01:21 PM   #12
AnsonFrs
AnsonFrs's Avatar
I actually don't have the paperwork he gave me right now but if I have to guess its is like mostly 0 and -1.2? Ish i can't tell you exactly but just top of my head when I was watching the monitor and it's all green!
Old 04-27-2015, 01:36 PM   #13
D_Thissen
D_Thissen's Avatar
Ive actually heard good things about this guy Will. I'm thinking about brining my car out to him since it pulls a bit to the left after I installed the springs. Not sure if that's a toe or camber thing (sorry newb).
The Following User Says Thank You to D_Thissen For This Useful Post:
wparsons (04-27-2015)
Old 04-27-2015, 02:27 PM   #14
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
I got my alignment done at a shop in the Midland/Lawrence area in Scarborough for 80... Caveat: their computer didn't have the brz specs, so we ended up using the WRX as the stand-in... Thankfully all I needed was alignment after installing the camber bolts, so it was just a matter of getting the -1.2 (couldn't get anymore though)
daiheadjai is offline   Reply With Quote
Alignment shop recommendations? (SEA) Koa Northwest 7 02-16-2015 07:18 PM
Alignment shop Bogie432 NY / NJ / CT / PA 1 04-07-2014 07:07 PM
Southside ATL Alignment Shop ??? RobertB Southeast 2 04-03-2014 01:26 PM
Alignment Shop SubaSteve Mid-Atlantic 3 01-22-2014 11:17 AM
Alignment shop DR 86 CANADA 4 03-27-2013 01:31 PM
