| CANADA Canada |
Drives: 14BRZ
Best shop in Toronto to get an alignment?
Anyone know where the best place to get an alignment in Toronto is? Preferably in markham/scarborough.
#2 |
Drives: 2013 Asphalt FR-S/2003 Honda Accord
I second this
#4 |
Drives: subaru
Scott at can-alignment. well worth the drive, won't find a better place
| The Following User Says Thank You to BRZ'13 For This Useful Post: | Burrcold (03-30-2015) |
#5 |
Drives: SSM BRZ
Also looking into this, how much do they usually go for??
#6 |
Drives: Subaru BRZ Limited
Yup Scott is a wizard!
#8 |
Alignment alone should be about $150ish from Scott. Well worth the drive though. He has a ton of racing experience and can not only set your alignment, but give insight into what specs you'll want.
#9 |
Drives: 2013 Whiteout FRS
i got my FRS done at K.S.L auto shop alignment and tire rotation for $80! i highly recommended! he didn't rush at all and took his time!
#10 |
What are the final specs at each wheel?
#11 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
I couldn't find a time that worked for me and Can-alignment, so I ended up going to NV Auto in Stoney Creek.
$110 for the alignment, they were able to dial this in pretty quickly (print out is at home): FRONTS (L/R): Camber: -2.1/-2.0 Caster: 6.3 (untouched, but my strut tops can adjust) Toe: 0.02 / 0.0 REAR (L/R): Camber: -2.0/-2.0 Toe: 0.10 / 0.09 |
#12 |
#13 |
Ive actually heard good things about this guy Will. I'm thinking about brining my car out to him since it pulls a bit to the left after I installed the springs. Not sure if that's a toe or camber thing (sorry newb).
| The Following User Says Thank You to D_Thissen For This Useful Post: | wparsons (04-27-2015) |
#14 |
Drives: 2003 S2000, 2008 Fit
I got my alignment done at a shop in the Midland/Lawrence area in Scarborough for 80... Caveat: their computer didn't have the brz specs, so we ended up using the WRX as the stand-in... Thankfully all I needed was alignment after installing the camber bolts, so it was just a matter of getting the -1.2 (couldn't get anymore though)
| Alignment shop recommendations? (SEA) | Koa | Northwest | 7 | 02-16-2015 07:18 PM |
| Alignment shop | Bogie432 | NY / NJ / CT / PA | 1 | 04-07-2014 07:07 PM |
| Southside ATL Alignment Shop ??? | RobertB | Southeast | 2 | 04-03-2014 01:26 PM |
| Alignment Shop | SubaSteve | Mid-Atlantic | 3 | 01-22-2014 11:17 AM |
| Alignment shop | DR 86 | CANADA | 4 | 03-27-2013 01:31 PM |
