| CANADA Canada |
Drives: Sliver FRS done the way I like it
Good shop to do Coilover install
Lookimg for a good shop in the GTA/ Mississauga to do my Coilover install , and that will set them up correctly and that I won't have any issues later .
Thanks Richard |
Drives: TRD Ultramarine '13
Might Car Mods.
Drives: hybrid + racecar + FR-S
have you tried Cyrious Garageworks? Scion Canada's drift FR-S driver?
Team Lexus IS300 race car '14 Lexus RX450h Sport Design daily driver '14 FR-S fri/sat/sun car: SARD LSR wing, Downforce front lip, Mann Engineering dampers, TRDsways, Milltek xhaust, AEM Intake, RAYS 57xtreme, OnPoint Dyno ECUTek tuned: +30rwhp! |
Just do it yourself and get a proper alignment and corner balance after. The setting up will be done with a proper corner balance. Literally took an hour to do all four on jack stands.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
Drives: 2013 Scion FR-S Firestorm MT
teknotik!
i-garage in markham. very reasonable price and they get it done on the same day you bring it in.
Drives: 1991 Acura NSX, 2013 Scion FRS
Speedstar if you want it done right
1991 BB NSX . 2013 WO FRS . 1978 Yamaha SR500
i'm sorry, what?
Drives: Canada
CanJam
CanAlignment Teknotik installing is easy, corner balance/alignment is what takes time. but make sure you know what you want the car to do... and understand the limits/pros/cons of your choice of coilovers.
| The Following User Says Thank You to 7thgear For This Useful Post: | wparsons (12-24-2013) |
Drive From Home
Drives: BRZ STI Performance
Corner balance and alignment is actually not the hardest part. The real hard part is to first get the ride height and the various adjustments to the shock cartridge right for your intended application.
For this car the best starting point for ride height is 15mm lower than stock, and go from there. Unless you bought them to slam the car for show then just disregard what I said above. BTW Ivan @ iGarage seems to get recommended everywhere. They did my STI pink springs and the job was great (no clunking on turns or anything). I'm waiting for Toyota to release the 86 By Tada Handling Pack so I can get those Sachs shocks to go with my springs, will probably go back to this shop. Last edited by krayzie; 12-24-2013 at 07:20 PM. |
| The Following User Says Thank You to krayzie For This Useful Post: | kickz (12-31-2013) |
#10 |
Drives: FR-S and Mazda 3 Sky
Scott @ CanAlignment is great, but you need to know what you want, not a bad idea to specify alignment specs.
#11 |
Scott is also a wealth of knowledge for settings if you can give him some background on what you want out of the alignment and some general settings that have worked for others.
Your best bet is to go see him with feedback on how the car handles with the factory alignment (push/oversteer, tire wear, etc).
#12 |
Thumbs up for Scott too. Had my car corner balanced and aligned there after installing coil overs myself.
#13 |
Engineer
Drives: WRB 2022 Subaru Brz
Does Scott have Experience working on the frs/brz platform. I am looking at getting my tarmac II installed. I am also wondering if i should get the car aligned right away or wait for the coil overs to settle and then get it aligned. And is it worth corner balancing the car as well?
#14 |
❤ fr-s love ❤
Drives: 13 Asphalt Scion FRS
Automatrix.....dont trust anyone else with my cars!!! They can do the install and the alignment in one stop!! Really cheap and they have worked with a lot of FRS/BRZ's before. Ask for Ed or Alic and tell them Rachel sent you. Shop is at Keele and Lawerence right off the 401.
Asphalt Scion FR-S Enkei | Aero Jacket | BC Racing | Invida | AFE | JL Audio | Seibon | Chargespeed | Cusco | Mishimoto | Spec D | www.themodmarket.com |
| anyone know a good audio install shop | NYCsubaruBRZ | NY / NJ / CT / PA | 6 | 01-16-2014 11:22 AM |
| Coilover and Springs Install at Performance Shop | F-T | Mechanical Maintenance and Tools | 22 | 12-12-2013 02:12 PM |
| HELP kw coilover top hat install problem | autoCAR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 10-18-2013 11:55 PM |
| HKS Coilover install | gtauto | AUSTRALIA | 16 | 04-21-2013 08:37 AM |
| Good coilover brand for DD | ngabdala | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 09-26-2012 04:59 AM |
