Drives: '23 CWP BRZ
Turn Signal in OEM DRL/HiBeam?
I've got an idea, but I'm not too sure it would work.
Do you think it'd be possible to buy an amber bulb/led, and replace the DRL/HiBeam in the OEM headlight with it, run a wire from it down to the turn signal, and splice it in? Therefore creating a turn signal in the headlight. Obviously this would be for a non Monogram/10Series/RS1.0 FRS. |
#2 |
Drives: Whiteout
I think it'd be possible, but then you lose your high beams, but it will make your car even more unique
#3 | |
Will ping DD about it |
#4 |
Drives: '23 CWP BRZ
#5 |
Drives: 06 Subaru Legacy
(dumb question) is there a thread somewhere or discussion that shows a picture of the front of the car, that points out what the stock function of each lamp is, and where it's located... for all the variants of the twins over time?
For stock standard editions, and also the Monogram/10Series/RS1.0 FRS. And if the locations have changed over time, or some countries have additional markers or lamps, pointing those out as well.
#6 |
Drives: FRS
why not just convert to BRZ headlights? oem quality, turn signal in the same place, oem xenons, led drl integrated already.
#7 |
Drives: '23 CWP BRZ
My current headlights are Bi-Xenon, LED DRL, Sequential Turn Signals, but I'm just trying to do something with OEM FRS lights. I love BRZ lights, but for how expensive they are..I'll pass.
#8 |
Drives: FRS
oh yeah i forgot. yours are modded frs lights already
#9 |
| Disable Turn Signal DRL? | 636 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-14-2014 08:09 AM |
| FRS turn signal mods | subiestyle | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 03-07-2014 01:34 AM |
| LED TURN SIGNAL BULB | myjobis2pimp | NY / NJ / CT / PA | 1 | 12-10-2013 06:28 AM |
| LED Turn Signal Issue | FR-S Matt | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 07-23-2013 12:47 PM |
| Anyone seen these turn signal/drl less? | djliquidsteele | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-15-2012 03:32 AM |
