Old 07-21-2013, 07:15 PM   #1
FR-S Matt
LED Turn Signal Issue
Hey guys. I've run into a minor issue with my LED turn signals. This past weekend I installed the Toyota USDM fog light kit with 6000k LED's. They work great, have 0 issues with them coming on. The kit has one wire that plugs into the signal harness in the spot where a blue stopper is in it. The other wire is just a ground wire on each fog. I've also got Tom's LED tail lights which were not repinned and full plug and play.
The issue I'm having now is my 6000k LED turn signals will only light up on signaling and hazard lights. If I turn the parking lights on or my HID's on, (fogs off) they do not illuminate as marker lights. I put back in the Amber stock turn signals and they do light up, so I know a fuse is not blown. The amber ones lit up on both sides.
I've swapped between 2 LED flasher relays, and the stock one as well with no change. I've reversed the LED turn signals on each side and swapped the bulbs from driver to passenger with no change. I've run out of ideas and I'm wondering if anyone else knowledgeable with electric might know the issue I'm running into. I've thought about it possibly needing a resistor but I am unsure.
Old 07-21-2013, 09:29 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If these lights only have two wires and one is ground, they're only a single circuit light (blinker OR marker). You have to have three wires for a dual circuit light (blinker AND marker).
Old 07-21-2013, 09:35 PM   #3
FR-S Matt
Even if the stock bulb performs in that same manner? The LED just doesn't perform the marker function but does blink.
Old 07-21-2013, 09:44 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
You said you tapped in to only one wire and sent the other to ground. That's only one circuit. The stock turn signal/marker bulbs are 7443s. Those are dual-element bulbs, so they have three wires. You'll need to have a dual circuit light to replace them to preserve functionality.
Old 07-21-2013, 09:46 PM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Is this the kit you're talking about?
http://www.ft86club.com/forums/showthread.php?p=1036075
Old 07-21-2013, 09:58 PM   #6
FR-S Matt
I found the problem:
Missing the two pins for the marker feature. This would explain why I only see turn signals.
Old 07-21-2013, 10:02 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
I was going to say, if it was the kit I linked above, you're reusing your stock light housings and the wires you're talking about are for the fogs. In that case I was going to ask if you got 7443 or 7440 replacement bulbs. Looks like you had the same thought. Easy fix.
Old 07-21-2013, 10:12 PM   #8
kALMIGHTY
Drives: TRD Ultramarine '13
Would switchbacks not fix this issue?
Old 07-21-2013, 10:15 PM   #9
FR-S Matt
4 Pin LED's will fix it. The LED's I received are only two pinned which only allow signaling. The other two pins are the marker function like the stock bulb has.
Learned a lot from this. Yes, that is the fog light kit I did. Very simple install. They look amazing with 6000k LED's in them to match my HID's.
I'm already working with HID_Powerhouse to get replacements. Kenneth has outstanding service as my entire car's LED's (Minus the Tom's tails) are from him.
Old 07-22-2013, 06:54 PM   #10
KI_ZN6
KI_ZN6's Avatar
Glad we got it sorted out (note: marker lights disabled) =) Now you are good to go XD
Enjoy your new goodies!
KI_ZN6 is offline   Reply With Quote
Old 07-22-2013, 06:57 PM   #11
FR-S Matt
Yep, I totally spaced on I had them ordered this way to prevent too much lighting with the fogs on. Unless there was a way to disable the turn signal markers while fogs were on then keep the signal function. That seems like a lot of work.
Old 07-22-2013, 07:14 PM   #12
FR-S Matt
Here is the result:
Thanks again Ken! Full LED solution on my car and the quality is outstanding!
Old 07-22-2013, 07:41 PM   #13
wbradley
Sarcastic SOB
wbradley's Avatar
One word: switchbacks
Old 07-22-2013, 08:30 PM   #14
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
yup i did the same thing. looks much better imo.
mezdup is offline   Reply With Quote
Turn signal issue Asphaltfrs1 Issues | Warranty | Recalls / TSB 3 06-21-2013 06:06 PM
Is it possible to change turn signal to drl? Enraged21 Scion FR-S / Toyota 86 GT86 General Forum 4 02-22-2013 12:52 PM
Does 6k HID's Go well With the Turn Signal Switchbacks J-Money Cosmetic Modification (Interior/Exterior/Lighting) 17 01-29-2013 10:41 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
