Old 03-18-2015, 08:58 AM   #1
TRD_Demon527
TRD_Demon527's Avatar
Drives: 2014 scion frs , 1987 toyota supra
SCCA pro solo what class
I am racing in the SCCA pro solo in May at MetLife stadium in jersey. I can't figure out what class I would be in and im having problems trying to find the class I need.
My mods are:
18x9 wheels
Racing seat and harness
Billet power blocks
Intake
Exhaust
Coilovers
Swaybars
Upper rear control atm bushings
Rear LCA
Strut bars
Short shifter
Crank pulley
Upgraded brakes front and rear EBC all around.
Open flash tablet with stage one bpb tune.
What class does that put me in?
I would like to keep everything simple.
TRD_Demon527 is offline   Reply With Quote
Old 03-18-2015, 09:23 AM   #2
TRD_Demon527
I normally run STX I keep hearing I should be in DSP because of the blocks. And I'm making a front splitter for the car also.
Old 03-18-2015, 09:29 AM   #3
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I think the power blocks move you out of STX in CSP. How far is the front splitter going to extend?
G_Ride is offline   Reply With Quote
Old 03-18-2015, 09:32 AM   #4
TRD_Demon527
2" from my front lip n 1.5" on each side of the bumper
Old 03-18-2015, 09:33 AM   #5
TRD_Demon527
Front splitter measures out to 68"x24"
Old 03-18-2015, 09:36 AM   #6
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
What tires?
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 03-18-2015, 09:36 AM   #7
TRD_Demon527
Nitto nto5 235/40/18
Old 03-18-2015, 09:43 AM   #8
G_Ride
G_Ride's Avatar
If the splitter extends beyond the bumper or beyond the front most part of the front wheel well opening, you'd be bumped from CSP to SM.
Old 03-18-2015, 09:45 AM   #9
TRD_Demon527
So then my frs is in street mod
Old 03-18-2015, 10:49 AM   #10
renfield90
The Stig's German cousin
Double check the street mod splitter allowances. IIRC I think it's only allowed to be wider than the bumper by a certain amount.
Old 03-18-2015, 10:55 AM   #11
TRD_Demon527
The front bumper is about 66" wide
Old 03-18-2015, 11:03 AM   #12
G_Ride
G_Ride's Avatar
You're right: No portion of the splitter may extend beyond the widest part of the front bumper/fascia as viewed from above.
See above
Old 03-18-2015, 11:40 AM   #13
renfield90
That's right. I knew it was more restrictive than intuition would suggest.
OP, this splitter you're building throws you all the way to prepared (probably F Prepared, but I try to avoid looking at the prepared rules so I don't know). If you don't really care about being competitive and just wanna have fun, by all means build the car that YOU want to have and just run it in whatever class it falls in.
Sans splitter you are in CSP. Running in STX with an illegal power mod is very likely to get you protested at a national event.
Old 03-18-2015, 11:56 AM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
only if you are fast enough for anyone to care.
I ran STX with an "illegal" mod (Greddy rear diff cover) and no one cared because I was more than 5 seconds off the podium pace.
-alex
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
What class would I be in for solo brianL. Tracking / Autocross / HPDE / Drifting 18 03-06-2014 02:53 AM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Anyone hear which ST(?) Solo class yet? Areddi Tracking / Autocross / HPDE / Drifting 34 09-20-2012 09:32 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
