17x9 Too wide for stock power?
Would running 17x9s be too wide for the stock power of the FRS?
I'm talking about mountain passes and precision handling. Would it be best to go with wheels with the same specs or would 17x9's be okay if the wheels were light, like RPF1s? |
Drives: 2014 Ultramarine FR-S
I just mounted 17x9 RPF1's with 245/40 Dunlop ZII Star Specs two weeks ago. I felt little/no difference in acceleration since the wheel/tire combo weight is similar to stock.
Drives: 2014 Pearl BRZ Limited
I'm Stg 2, but for what it's worth, I felt no difference either, apart from A LOT more grip. However this could be misinterpreted by some, I'm sure, as a loss in power. It's a lot less tail happy now.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
Off Topic
Question for the 17x9 people: have you noticed a change in gas mileage since you've put your wheels on?
Drives: 2013 Raven
Drives: FRS
wheel size is one thing... you still need to factor in the type of wheel and weight, and tire size and stickiness.
i'm sorry, what?
Drives: Canada
17X9 is a wheel size.....
without know what tires you want to put on it there's really no way to answer your question.
Drives: '13 Argento MT FR-S
I'm in the same boat (on ZII non Star Specs tho). I feel no noticeable loss of acceleration, and an increase in MPG (over my winter 225/45R17 Conti DWS) back to nearly what I acheived on stock tires. You can actually get a 245/40R17 on a 17x9 to weigh in LESS than stock, but most will be very close to the OEM weight.
| How wide can I go with the stock rims | redburn86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-09-2014 08:48 PM |
| 215 wide tire on 8.25 wide rim question | barabia | Tracking / Autocross / HPDE / Drifting | 15 | 06-30-2014 08:59 PM |
| Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** | LSD Motorsports | Groupbuys | 246 | 08-29-2013 01:35 PM |
| How wide and aggressive on stock tires? | euroshowoff | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 04-19-2013 06:40 PM |
| Picture Request: Stock Turanzas on 8" wide wheels | Robmilkshakes | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-17-2013 06:05 PM |
