Old 03-03-2015, 05:57 PM   #1
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
HELP: Rydeen Duo and Beatsonic BU Cam Adapter
Losing my mind here, bear with me. Trying to set up my backup camera using the Beatsonic BSU52 and Rydeen ZH07-150B.
Installing the camera itself was a breeze...all the wires come together to a connector. It's the rest of the harness I'm having the issue with. Bold are the parts I need help on...
On the camera side/back of the car (Rydeen harness):
-Connector for the camera [easy]
-"reverse light power+"[assuming this goes to the hot wire on the reverse lights?][EDIT: found some info for this and the ground saying with the OEM radio I just tape these off...can anyone confirm?]
-ground [duh]
On the radio side/front of car (Rydeen harness):
-yellow RCA [duh]
-red "reverse power anode output" [connects to white wire on Beatsonic harness?]
On the radio side/in dash (Beatsonic Harness):
-inline 16-pin harness [duh]
-yellow RCA [duh]
-white wire with female bullet connector "camera power" [is this the one that attaches to the red "reverse power anode output" from the camera harness?]
-red wire "ACC" [do I really have to locate and splice into an ACC power source? really?]
-random purple wire with connector pin on the end ["for some models"]
I've got a pretty good grasp on automotive electronics but I've never played with anything like this before...
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 03-05-2015, 09:21 PM   #2
RickyBobby
Drives: 2013 Firestorm FR-S AT
http://www.beatsonicusa.com/bcus3-536.html
Instruction and DIY for FRS links at bottom of page.
More info here: http://ae64.com/Rear-camera-16p-operation.htm
and here: http://ae64.com/Rear-camera-install-16p-BeSpoke.htm
RickyBobby is offline   Reply With Quote
Old 03-06-2015, 11:46 AM   #3
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
The Rydeen DUO (ZH07-150B) and Rydeen MINy models (as well as many other cameras) will work from 6V. So you could power any of those directly from the OEM radio's camera power pin, and not need to tap into +12V ACC power. You would have to cut a wire on the Beat-Sonic harness to access the 6V power signal.
For any camera that you're unsure of its minimum operating voltage, test on a TV or monitor powered from 6V (using batteries) to see if it works. Some cameras will work from a supply as low as 3.5V. Also check in low light, as some cameras were found to look OK from 6V in daylight, but had image degradation from 6V at night (and needed slightly more than 6V to work properly).
SVXdc is offline   Reply With Quote
Old 03-06-2015, 12:49 PM   #4
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
See comments below
-"reverse light power+"[assuming this goes to the hot wire on the reverse lights?][EDIT: found some info for this and the ground saying with the OEM radio I just tape these off...can anyone confirm?] - run power wire from camera to power wire from beat sonic harness - ground the camera ground wire to anywhere in the trunk area
-ground [duh]
-yellow RCA [duh]
-red "reverse power anode output" [connects to white wire on Beatsonic harness?] - YES
-yellow RCA [duh]
-white wire with female bullet connector "camera power" [is this the one that attaches to the red "reverse power anode output" from the camera harness?] - YES
-red wire "ACC" [do I really have to locate and splice into an ACC power source? really?] - YES REALLY
-random purple wire with connector pin on the end ["for some models"] - this wire is your reverse trigger wire - this gets spliced into your reverse signal wire, then goes to radio harness - pin with connector end gets pushed into harness directly
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 03-06-2015, 05:41 PM   #5
Silver Ignition
APEXHNTR
GOT IT! Thanks
#1867 of 2500
Old 03-07-2015, 09:08 AM   #6
Silver Ignition
APEXHNTR
Would any of you fine gentlemen know how to either adjust or remove the grid pattern from the backup cam display on the 2014 Bespoke head unit? Diagnostic screen doesn't look the same as the others I've seen and the diagnostic screen on my 2014 Bespoke has a "Camera Setting" button but the button is "faded"/disabled.
#1867 of 2500
Old 03-10-2015, 02:37 AM   #7
jonzhuxD
Drives: Ultramarine FR-S
You can not do anything about the built in grid lines, they are not adjustable/removable. Disable the camera's built in lines. (I believe you cut the green wire to do this)
jonzhuxD is offline   Reply With Quote
The Following User Says Thank You to jonzhuxD For This Useful Post:
Silver Ignition (03-10-2015)
Old 03-10-2015, 09:40 AM   #8
Silver Ignition
APEXHNTR
Bummer.
Green wire already cut.
#1867 of 2500
Old 03-11-2015, 02:15 AM   #9
jonzhuxD
Bummer.
What's the problem? Double grid lines?
Old 03-11-2015, 08:38 AM   #10
Silver Ignition
APEXHNTR
No only one set of grid lines but they point down at the ground…"green" is only about 12" off the bumper, red is ON the bumper
#1867 of 2500
Old 03-15-2015, 07:44 AM   #11
SVXdc
SVXdc's Avatar
I didn't know that any of the BeSpoke HUs generated parking guide lines. Are you sure those are coming from the HU? Try temporarily feeding it a video signal from some other source (game console, VCR, DVD player, digital camera, security cam, etc.).
On the Rydeen DUO, you cut the green loop wire to enable the camera's guide lines, or join to turn them off.
As for the HU's menu being disabled, it might require that you ground the HU's parking brake input pin. I'm not sure about 2014, but on previous years, FR-S did not have the 16-pin harness at all (thus no p. brake signal connected to HU).
Try temporarily connecting that terminal to chassis ground. Use a single strand taken from a piece of small-gauge stranded wire. Make sure you don't touch any other pins on the 16-pin socket.
The Following 2 Users Say Thank You to SVXdc For This Useful Post:
Silver Ignition (03-16-2015), tracerit (10-16-2015)
Old 03-16-2015, 09:19 AM   #12
Silver Ignition
APEXHNTR
that's my problem right there, I was doing the opposite, I thought cutting the wire takes the gris off...
#1867 of 2500
Old 03-23-2015, 07:48 PM   #13
SVXdc
SVXdc's Avatar
I (and I'm sure others) would be interested to hear if grounding the HU's parking brake input pin makes that "Camera Setting" button be not grayed out.
Can you post a picture of that screen? Plus any other screens that you navigate through to reach that one (if it's not the first one you reach when you initially enter diagnostics mode).
Old 03-24-2015, 09:14 AM   #14
Silver Ignition
APEXHNTR
Which pin is the parking brake input? Is it on the Beatsonic harness or on the factory harness?
#1867 of 2500
Rydeen Duo on BRZ Limited sure74 Electronics | Audio | NAV | Infotainment 343 01-22-2019 07:28 PM
rydeen mini backup cam jknakes Electronics | Audio | NAV | Infotainment 21 05-08-2015 11:04 PM
How to wire up with Rydeen Duo Hyperian Electronics | Audio | NAV | Infotainment 6 05-16-2014 04:20 PM
Pioneer HU and Rydeen Duo Camera pauland Electronics | Audio | NAV | Infotainment 5 03-04-2014 06:20 PM
Rydeen Duo installed on a Preimum sparks Electronics | Audio | NAV | Infotainment 9 10-16-2012 06:39 PM
