Old 05-15-2014, 11:12 PM   #1
Hyperian
Drives: BRZ 2014
How to wire up with Rydeen Duo
so i got the Rydeen Duo and the SVXdc harness. I'm seeing that the camera has a red wire coming off the RCA plug, and a wire that goes along with the ground wire with the terminal ring.
In the "electrical connection" instruction for the camera, the the red wire from the RCA is the "reverse trigger" and the red wire with the terminal ring is the "reverse wire"
Do i hook up the reverse wire or reverse trigger to the SVXdc harness? The harness has an RCA and a red wire with a black wire that loops back onto itself (into another slot)
Hyperian is offline   Reply With Quote
Old 05-15-2014, 11:50 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Did you check the main thread on the Rydeen Duo? http://www.ft86club.com/forums/showthread.php?t=17020
cnk is offline   Reply With Quote
Old 05-16-2014, 01:50 AM   #3
Hyperian
Drives: BRZ 2014
yea, it doesn't specify what happens to that red wire next to the RCA. But one person does say he connected the black and red wire pair to the amp connection, which i dont intend to do.
Old 05-16-2014, 10:08 AM   #4
cnk
IIRC, the reverse trigger and reversing wire do the same thing. Other people that have installed it just hook up the reverse trigger and then cut or tape off the reversing wire.
Found it: Start reading from post #118 in the thread I linked to you above.
Old 05-16-2014, 10:31 AM   #5
TM
TM's Avatar
Drives: DGM BRZ 6MT
I have the Rydeen Duo with the SVXdx harness, too, but I don't remember how it looks like. Can you take a picture of what you're asking? I remember everything was plug and play. The updated harness even has a ground, so you don't need to ground it to a screw.
TM is offline   Reply With Quote
Old 05-16-2014, 12:41 PM   #6
Hyperian
Drives: BRZ 2014
I took a multimeter to the rydeen duo and the ground from RCA and the terminal ring are connected. and so are the two red reverse wires.
so it looks like i just hook up one of the wires and not use the other one!
Old 05-16-2014, 03:20 PM   #7
TM
TM's Avatar
Drives: DGM BRZ 6MT
Yeah, there is set of red and black wire closer to the reverse camera and a set near the dash receiver.
Since the dash receiver provides both ground and power, I just taped up the the other ones.
Rydeen Duo on BRZ Limited sure74 Electronics | Audio | NAV | Infotainment 343 01-22-2019 06:28 PM
Pioneer HU and Rydeen Duo Camera pauland Electronics | Audio | NAV | Infotainment 5 03-04-2014 05:20 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
Rydeen Duo installed on a Preimum sparks Electronics | Audio | NAV | Infotainment 9 10-16-2012 05:39 PM
Info on Rydeen MN312S? dnr Electronics | Audio | NAV | Infotainment 0 09-12-2012 04:31 PM
