Old 09-11-2012, 12:18 PM   #1
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Rydeen Duo on BRZ Limited
I mounted a Rydeen Duo (ZH07-150B) in the stock rear view camera location on a BRZ Limited.
The camera
Removed the trunk fascia
If you look close there is an outline where the stock camera would go
I used the supplied double stick tape as a template
Hole drilled, camera mounted
From the underside
Sharing the trunk release grommet
Getting it back together
Final product
Once the wire is through the trunk release grommet it is pretty simple to
follow those wires through the trunk lid and in to the cargo area via the wire
boot. That was all the time I had plus I was still waiting for my RCA w\pins
from SVXdc which came the next day.
RCA w\pins from SVXdc
So the hard part is done. I will run the wires, get power and plug in the RCA
as soon as I get a chance.
Definitely happy with the look. This camera seems to be built very well. It is
pretty heavy for such a small device. First time I closed the trunk I thought
about where the quality of this camera will be worth the extra few bucks.
Enjoy
sure74 is offline   Reply With Quote
The Following 30 Users Say Thank You to sure74 For This Useful Post:
autobrz (06-18-2013), B L U E S L A T E (01-10-2013), BRZranger (09-17-2012), BRZY (09-14-2012), Brzzee (04-03-2013), Creole (03-26-2017), davesbrz (01-07-2014), Foobar (09-11-2012), Gintsuki (11-20-2013), grst1 (09-28-2012), Guff (09-11-2012), joergasm (01-22-2014), johnb831 (11-22-2012), JPxM0Dz (09-11-2012), kask2_6.0 (10-22-2012), Lee358 (09-17-2012), notout86 (04-03-2014), Ornelas66 (03-02-2015), pumice (12-31-2012), Sensisnow (04-08-2013), SirBrass (04-03-2015), sparks (09-11-2012), Sportsguy83 (11-23-2012), SVXdc (09-11-2012), tripjammer (01-29-2013), Turbowned (10-07-2014), Vlad (10-03-2012), Wafflejuice (12-18-2013), Wolfking (02-26-2014), zoomzoomers (09-11-2012)
Old 09-11-2012, 12:26 PM   #2
Foobar
SLO NO MO
Foobar's Avatar
Looks awesome - that is definitely the way to go for a stock looking camera install. I must be blind though, I don't see the outline on the fascia where the OEM camera would've gone...
Old 09-11-2012, 01:15 PM   #3
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Pics of the camera picture quality? For that kind of money it should be pristine I'd hope...
michaelahess is offline   Reply With Quote
Old 09-11-2012, 01:40 PM   #4
djdnz
1337
Drives: 2013 BRZ WRB S/C
Looks really good, how much was the total investment so far?
djdnz is offline   Reply With Quote
Old 09-11-2012, 02:06 PM   #5
Foobar
SLO NO MO
Foobar's Avatar
I've seen the Duo sell for around $140.
As far as cost = picture quality, for these cameras, picture quality is actually the least part of the cost. Even a $12 camera produces a great picture on our head unit. Most of the cost goes into the size and quality of the housing. A $12 camera is going to end up with moisture in it and will fail quickly.
I have both a $12 camera and a $115 camera. Can't tell the difference between the video quality, but one's plastic, big, and had moisture fogging up the lens after being exposed to the elements. The other's metal, slim, and has endured rainstorms and my pressure washer without a problem.
Old 09-11-2012, 03:01 PM   #6
sure74
sure74's Avatar
Thanks.
Hard to see in the picture but they are there.
Like I mentioned, it isn't hooked up yet. I tested it on my kitchen TV to be sure it works and that the lines were deleted.
Thanks.
139.00 for the camera via eBay
21.80 for the RCA w\pins from SVXdc (also got the ground wire)
160.80 total
Agreed. I feel like it was worth the money just based on how it looks. As long as I don't run over any toys when backing out of the garage and I never have to swap it out I will be happy.
Old 09-11-2012, 05:17 PM   #7
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
You know what I want? A front bumper view camera so I dont run over any parking curbs.
mrha is offline   Reply With Quote
The Following 5 Users Say Thank You to mrha For This Useful Post:
636 (12-13-2012), brzadrian (04-30-2014), PoWn3d_0704 (06-20-2013), TheBRZsKnees (12-11-2017), unsurety (04-15-2014)
Old 09-11-2012, 06:23 PM   #8
Foobar
SLO NO MO
Foobar's Avatar
I have a Curb-Alert for that. It's a proximity sensor with an audible alert.
The Following User Says Thank You to Foobar For This Useful Post:
mrha (09-11-2012)
Old 09-11-2012, 06:36 PM   #9
GregV
Drives: Kia Stinger GT2
After driving a jeep for 10 years I can say it only took me once to learn the difference
GregV is offline   Reply With Quote
The Following User Says Thank You to GregV For This Useful Post:
sweeney208 (03-13-2013)
Old 09-11-2012, 08:54 PM   #10
xcelir8brz
Drives: 2013 BRZ Limited
You did exactly what I was planning on doing with my BOYO that I'm waiting to receive from Amazon. Looks great!
xcelir8brz is offline   Reply With Quote
Old 09-14-2012, 03:30 AM   #11
BRZY
BRZY's Avatar
Drives: World Rally Blue BRZ
subbed for final results!
BRZY is offline   Reply With Quote
Old 09-14-2012, 05:08 PM   #12
sure74
sure74's Avatar
Like I had mentioned, the hard part was done. Ran the power to the factory amp (+12V Accessory)
and grounded it on one of the amp bolts. Ran the video wire up the drivers side of the car
(nice and neat) and under the dash to the back of the stereo. The Rydeen came with plenty of
cable to reach. Plugged the pins on the RCA from SVXdc in to the 16 pin harness as per SVXdc's
instructions and connected the camera.
Used the lines to back in to a spot, car was dead center in the spot. No need to adjust the lines
(close enough) since I put the camera where the head unit was expecting it.
First green line, about 7' from the curb
Yellow line, about 4' from the curb
Red line, about 3' from the curb
All in all this was not a difficult installation. Just be careful not to scratch anything when removing
/re-installing the trunk fascia and be careful when you have the stereo haning out of the dash
that it doesn't scratch the clock area and you should be good.
The Following 10 Users Say Thank You to sure74 For This Useful Post:
1strwdcar (02-16-2013), Giccin (03-12-2013), Guff (09-17-2012), johnb831 (09-15-2012), lordtakuban (12-04-2012), NorCalRider (03-23-2013), Ornelas66 (03-02-2015), RYU (09-14-2012), SVXdc (09-21-2012), tripjammer (01-29-2013)
Old 09-15-2012, 12:57 AM   #13
xcelir8brz
Here is my Boyo installed (copy of your installation for the most part):
The Following 5 Users Say Thank You to xcelir8brz For This Useful Post:
Giccin (03-12-2013), Guff (09-17-2012), johnb831 (09-15-2012), SVXdc (09-21-2012), tripjammer (01-29-2013)
Old 09-15-2012, 01:44 PM   #14
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
nice
mikeg7827 is offline   Reply With Quote
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 02:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 02:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 11:32 AM
Want to buy a BRZ Limited AT kgc Northwest 1 06-16-2012 11:45 PM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 12:50 PM
