Old 02-27-2015, 06:11 PM   #1
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
New Greddy T620Z??
T620Z
What's the word?? Any good? Worth the $$$
Celigts is offline   Reply With Quote
Old 02-27-2015, 06:19 PM   #2
You need a built engine to get the full potential out of it.
Celigts (03-01-2015)
Old 02-27-2015, 08:27 PM   #3
kbye
kbye's Avatar
Drives: 2014 FR-S
Low end vs top end, take your pick:
I would probably wait for the garrett turbo upgrade before making a choice.
kbye is offline   Reply With Quote
The Following 2 Users Say Thank You to kbye For This Useful Post:
Celigts (03-01-2015), hmong337 (06-02-2015)
Old 03-01-2015, 11:03 AM   #4
Celigts
Celigts's Avatar
I'm going to go with the Ptuning turbo ... Been wanting to pull the trigger for some time but wanted to waive for greddy to make their v2 kit ... and this one doesn't seem like it's up to my expectations.
The Following User Says Thank You to Celigts For This Useful Post:
raven1231 (07-15-2016)
Old 05-28-2015, 11:41 PM   #5
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
Is anyone running one of these?
cameronjones239 is offline   Reply With Quote
Old 06-01-2015, 08:51 PM   #6
mrk1
Drives: Sterling BRZ Ltd
Is there any flow or wheel trim info on this 620Z?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 06-01-2015, 10:13 PM   #7
robinsonbond007j
I've been running a PTUNING turbo for over 15k and put it through a PA winter. From my stand point PTUNING is a great turbo kit. Hasn't let me down yet. Still getting around 31 mpg when on travel days but only around 20 on back roads lol.
robinsonbond007j is offline   Reply With Quote
The Following 2 Users Say Thank You to robinsonbond007j For This Useful Post:
raven1231 (07-15-2016), rb6freak (06-03-2015)
Old 06-01-2015, 10:14 PM   #8
cameronjones239
What's that have to do with Greddy...?
Old 06-02-2015, 03:01 AM   #9
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
@rocketbunny86 is using it, maybe he can chime in.
Build Thread
Instagram
Old 06-02-2015, 05:46 PM   #10
cameronjones239
Hopefully someone can, I haven't found anyone running it yet. Curious how it'd be on a low boost set up with the stock block. Keep it around that 280-320whp with room to grow into the deep 300's-low 400's. Or if I'm better off running the 518 and swap to the 620 or Garrett down the road after the motor is built.
Old 06-02-2015, 06:02 PM   #11
ztan
Drives: Toyota 86
I'm pretty happy with the T518Z. Greddy kit piping, Tomei overpipe, 3" exhaust. Using the Profec boost controller and gain at -7, I get a flat 0.65 bar boost all the way to redline, overboosts if gain is set any higher - I think there is a bit more headroom that can be used with the T518Z before it runs out of puff. Silvia guys run up around 1.4 bar on it. Have not wound up the boost much more yet - not sure that stock internals on our fuel would handle it.
ztan is offline   Reply With Quote
The Following User Says Thank You to ztan For This Useful Post:
cameronjones239 (06-02-2015)
Old 07-15-2016, 12:18 PM   #12
foreverlost1986
Drives: 2017 BRZ yellow series
KIT is Fuked
I am running this kit, It over boost like crazy on stock motor. When greddy did there RND for this kit they tested it on a built motor with 10:1 compression. I have to put the stock exhaust back on to stop it from boosting to up 20psi.
foreverlost1986 is offline   Reply With Quote
Old 07-15-2016, 12:55 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://www.ft86club.com/forums/showthread.php?t=108228
You dont have a boost cut on your tune?
Old 07-15-2016, 02:49 PM   #14
foreverlost1986
yea. but from what Greddy and my tuner tells me its a hardware problem and it cant be fixed with a tune.
there was 3 ways to fix the problem.
1) new Spings for the wastgate
2) external wastegate (not sure it will work)
3) or built motor.
the problem was the wasgate not open with the compression differents
Greddy Base Map for FRS Greddy Turbo Kit hiranak Software Tuning 10 10-27-2014 06:55 AM
*** [DECIDED] GReddy *** Full Blown vs GReddy slisgrinder Forced Induction 31 08-13-2014 02:24 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 06:09 PM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
