| View Poll Results: Boost Controller | |||
| Manual boost controller |
5 | 14.29% |
| Electronic boost controller |
23 | 65.71% |
| No boost controller |
7 | 20.00% |
| Other |
0 | 0% |
| Voters: 35. You may not vote on this poll | |||
Drives: 2013 Scion FRS
Boost Control
Trying to see what people are running and why. Trying to understand pros and cons. I planned on a manual boost controller however my tuner said he is against them (boost spike). I would love for the community to weigh in.
Manual boost control Electronic boost control No boost control Other |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Do you really need a boost controller?? I am not going to be running one as I am only running 10psi
#4 | |
Not Bаnned Anymore
hahaha no I don't I love the car in NA form to be honest. I just ran out of other things to do to the car so that's next on the list followed by a BBK eventually but spending like 6 grand on brakes is a bit hard to swallow. |
#FiftyShadesOfBlue
Drives: 2015 FR-S
This seems to be one of those things were people have no problem spending the money on the turbo kit and then try to cheap out on supporting mods.
The electronic one is going to be more precise, don't skimp out here.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
| The Following 3 Users Say Thank You to Tectoniic For This Useful Post: |
#6 | |
Junior
Drives: a car
http://www.speedhunters.com/2014/09/...rol-questions/
| The Following 2 Users Say Thank You to cdrazic93 For This Useful Post: | snowdog (07-11-2016), Sportsguy83 (07-12-2016) |
#7 | |
Drives: '95 delSol, '13 EvoX, '14 Leaf
Airborne at your service
Drives: '17 BRZ Series.Yellow
My pulley is my boost control
| The Following User Says Thank You to weederr33 For This Useful Post: | thunderlights (07-15-2016) |
Drives: none
This is a fairly common mistake that people make when trying to extract maximum performance out of a turbo installation. Just running wastegate pressure only is perfectly acceptable but you will be leaving a little bit of performance on the table. It's important to understand how wastegates work. I won't go into a lot of depth here but the TL;DR is that the wastegate actuator will partially open several PSI before it reaches the equilibrium pressure it is designed for. This will slow the rate at which the turbine spools, making it take longer to build boost. If you use an electronic boost controller with a solenoid valve that blocks the boost pressure from getting into the wastegate until target pressure is reached the turbo will spool faster. How much faster? Is it worth the cost? that all depends and is a much longer discussion.
If I wanted to run 10PSI of boost I would opt for a lower pressure wastegate actuator (say 5-7PSI) and pair it with a nice EBC for maximum spool.. but that's just me. Edit: Most FA20 builds can't run enough boost/make enough power to justify an external wastegate but there are some interesting "upgraded" internal gate actuators that have both an upper and lower port which is really the BEST way to control boost with an EBC... Just blocking boost to a single port can only get you so far and you will still get the gate creeping open before your set point. A two port actuatator allows you to use boost to FORCE the wastegate to stay closed until you want it to open, regardless of the spring strength. -Matt |
| The Following User Says Thank You to armstrom For This Useful Post: | Sportsguy83 (07-12-2016) |
#10 |
Lot of good comments on the EBC. Any strong supporters of MBC? or wastegate only?
#11 |
Drives: Built FA20
EBC's can do a lot more than mechanical controllers (obviously). The TruBoost for instance allows you to set alarms, has auxiliary outputs that are triggered for certain conditions (e.g. an alarm output, triggered when the alarm goes off) that can be wired to whatever you want... It allows you to set the "spring pressure", which can help you improve spool time (and/or overboost, be careful).
As mentioned, it has fail-safes in place if something does go wrong. I would recommend getting an electronic controller. Save yourself the hassle of running line from your engine bay into the cabin of your car and back out to the engine bay (manual controller). |
| The Following User Says Thank You to nickw14 For This Useful Post: | snowdog (07-20-2016) |
| Boost Control Basics | pixel67 | Forced Induction | 2 | 06-06-2015 11:27 PM |
| electronic boost control. | Jaden | Forced Induction | 10 | 02-02-2015 12:28 PM |
| Need help with boost control install. | C130NAV | Forced Induction | 1 | 05-16-2014 02:10 PM |
| Ecutek boost control with ebcs help. | gdrider77 | Software Tuning | 11 | 02-02-2014 10:06 PM |
| Guys running EcuTek boost control | ATSAaron | Forced Induction | 14 | 09-14-2013 04:08 PM |
