Old 02-17-2015, 11:54 AM   #1
redlined600
redlined600's Avatar
Drives: Fr-s
koni yellow max spring rate
Anyone know what the max spring rate the koni yellows can handle? Anyone have a dyno of the ots koni yellows.
Thanks.
Old 02-17-2015, 02:52 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
@Racecomp Engineering is probably the most likely to know
Old 02-17-2015, 03:12 PM   #3
I have not seen a dyno of the Koni Yellows for 86. My guess is they could be fine with up to 350 lbs/in springs, but that's just a guess.
- Andy
Old 02-17-2015, 03:17 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
afaik they're rated for up to 500lb/in ishhh (info from back when I was didling with VWs)
not sure if anyone has a BRZ/FRS koni dyno but I'd be surprised if they're anything different from their general application, which is a small firming of the low and high speed compression (barely noticeable) and a significantly higher high-speed rebound with a fast ramp-up rate.
a quick and cheap fix for most drivers, but will "jack down" quickly over successive bumps.
Old 02-17-2015, 03:21 PM   #5
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
When I ran koni yellows on my cobalt i ran them at 1/2 turn from full soft anything past 3/4 would result in shock jacking.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 02-17-2015, 03:23 PM   #6
ayau
Drives: Some rust bucket
- Andy
Can you explain or provide an article that explains the effects of an overdamped and underamped shock?
Old 02-17-2015, 03:28 PM   #7
This might help. I think I covered that in here.
http://www.ft86club.com/forums/showthread.php?t=81062
EDIT: I didn't really talk about underdamped situation much in there. That will result in a bouncy ride (you hit a bump and the chassis takes a few oscillations to settle).
- Andy
Old 02-17-2015, 03:31 PM   #8
swarb
right around 450-500lbs/in from my experience in the fwd honda civics.
WTB: Koni yellow struts and RCE yellow springs nlowell Brakes, Suspension, Chassis 2 05-20-2014 03:10 PM
koni yellow question sweeney208 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-03-2014 08:09 PM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
Best Spring Rate please help whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-30-2012 09:02 PM
