Drives: Fr-s
koni yellow max spring rate
Anyone know what the max spring rate the koni yellows can handle? Anyone have a dyno of the ots koni yellows.
Thanks. |
#2 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
@Racecomp Engineering is probably the most likely to know
#3 |
I have not seen a dyno of the Koni Yellows for 86. My guess is they could be fine with up to 350 lbs/in springs, but that's just a guess.
- Andy |
#4 |
i'm sorry, what?
Drives: Canada
afaik they're rated for up to 500lb/in ishhh (info from back when I was didling with VWs)
not sure if anyone has a BRZ/FRS koni dyno but I'd be surprised if they're anything different from their general application, which is a small firming of the low and high speed compression (barely noticeable) and a significantly higher high-speed rebound with a fast ramp-up rate. a quick and cheap fix for most drivers, but will "jack down" quickly over successive bumps.
#5 |
StreetKart
Drives: 2014 Scion FR-S Monogram
When I ran koni yellows on my cobalt i ran them at 1/2 turn from full soft anything past 3/4 would result in shock jacking.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#6 |
Drives: Some rust bucket
#7 | |
http://www.ft86club.com/forums/showthread.php?t=81062 EDIT: I didn't really talk about underdamped situation much in there. That will result in a bouncy ride (you hit a bump and the chassis takes a few oscillations to settle). - Andy |
#8 |
right around 450-500lbs/in from my experience in the fwd honda civics.
| WTB: Koni yellow struts and RCE yellow springs | nlowell | Brakes, Suspension, Chassis | 2 | 05-20-2014 03:10 PM |
| koni yellow question | sweeney208 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 02-03-2014 08:09 PM |
| FS: RCE Yellow, Koni struts and pre cut housing for Koni's. | Dinko | Brakes, Suspension, Chassis | 21 | 12-16-2013 10:32 AM |
| -Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! | OrbitalEllipses | Mid-Atlantic | 21 | 06-14-2013 12:10 PM |
| Best Spring Rate please help | whitefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 09-30-2012 09:02 PM |
