Old 02-02-2014, 05:16 PM   #1
sweeney208
sweeney208's Avatar
Drives: red subaru brz limited
koni yellow question
so ive been trying to look around and figure out what i want to do for suspension. I autocross when I can but plan on doing it much more often. Everybody with recommendations says to go with the koni yellows. So I wanted to order them and found the word inserts. After figuring out what the hell that meant, I dont think i want to go that route. I also read on here that Koni was going to be making a set that did not have inserts and were just bolt on ready to go. Has this happened? Does anybody know if it is going to happen? The posts I read were from 2012 and I cant seem to find anything online that arent inserts other than aftermarket built coilovers USING konis..
So any suggestions on what to do? I have eibach springs coming in for a 1 inch drop.. I come for the world of lifting jeeps so this is all a bit new to me haha
sweeney208 is offline   Reply With Quote
Old 02-02-2014, 05:47 PM   #2
wparsons
wparsons's Avatar
Bilstein has two lines of struts/shocks out (or coming out VERY soon). They're drop in solutions, not inserts like the Koni fronts. They're not cheap, but they're worth it if you want quality dampers.
If you're going to get more serious about autox, I would honestly look at other spring options than eibach. Nothing against eibach, but there are better options for autox out there.
flickr
Old 02-02-2014, 05:48 PM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
http://www.redline360.com/koni-yello...frs-front-rear
That literally took me 23 seconds to find and post
Old 02-02-2014, 05:57 PM   #4
wheelhaus
wheelhaus's Avatar
That link shows the two front are inserts.
wheelhaus is offline   Reply With Quote
Old 02-02-2014, 10:19 PM   #5
sweeney208
sweeney208's Avatar
those are the inserts but thank you
Old 02-03-2014, 10:25 AM   #6
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I have the koni's and have no issues with them. I bought a second set of front struts used for like $50, and that's what I used to cut.
Ranatsu is offline   Reply With Quote
Old 02-03-2014, 10:29 AM   #7
sshole
Koni said they were releasing a front strut replacement (direct bolt-on, no cutting/inserts) on the 2002 WRX way back.
They still haven't released that unicorn product.
sshole is offline   Reply With Quote
Old 02-03-2014, 11:23 AM   #8
sweeney208
sweeney208's Avatar
anywhere to get them specifically or did you find somebody that did coilovers or something and was just looking to get rid of them? I mean ill try doing the inserts because it doesnt look hard; just only if i can get another set of front struts for cheap.. which I didnt think they would go that cheap.
Old 02-03-2014, 11:24 AM   #9
sweeney208
sweeney208's Avatar
so its not happening. at least not soon. haha any other companies you guys know of that do direct bolt on that are decent? I dont know enough about suspension to know good from bad.
Old 02-03-2014, 11:28 AM   #10
sshole
Bilstein just released a set of front+rear dampers that are direct replacement. I think they're something like $900 for the set, though, so there's that.
Old 02-03-2014, 11:30 AM   #11
suaveflooder
First off, I love all your posts! You seem very knowledgeable! What would be a better spring option? I have eibach pros and I'm not opposed to swapping them out for something better. Also been playing with the idea of getting something like a KW V1 as it would just be a touch more, but I'm worried this will be too much of a street only coilover. I too will be doing the occasional autox and open track event. I know little about the adjustment, which is why I wouldn't dump money into an adjustable coilover like a V3, but on more track time and tires. Help would be amazing!
suaveflooder is offline   Reply With Quote
Old 02-03-2014, 11:38 AM   #12
wparsons
wparsons's Avatar
In all honesty, it depends on what you want out of the springs.
I would personally go with either RCE yellows or Swift sport springs on stock struts. If you're going with Bilstein or Koni's, I'd also look at RCE Tarmac springs.
If you want coilovers and like KW but want more track focus, look at the RCE T0 or TII. TO's are stiffer versions of KW V1's and TII's are stiffer versions of KW V3's. Both the T0 and TII are made by KW, so there's no difference in quality. Since you're far from a snowy area, you could also look at the ST coilovers, they're apparently comparable to V1's but less money (not stainless, just zinc coated).
flickr
Old 02-03-2014, 11:40 AM   #13
sweeney208
sweeney208's Avatar
i mean the konis were something around the high 600s i believe so if the quality is that much better and they are also direct replacement... seems somewhat justifiable?
Old 02-03-2014, 11:53 AM   #14
wparsons
wparsons's Avatar
$300 to not hack up the stock struts doesn't seem outlandish to me, this way you still have the usable stock parts if you ever want to return to stock.
flickr
Koni Yellow Shocks available at Redline360 Redline360 Brakes, Suspension, Chassis 182 01-13-2015 12:11 AM
Review: RCE Yellow Springs and KONI shocks Grimlock Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 03-27-2014 10:58 AM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
F/S: Koni Yellow struts and H&R Supersport springs $650!! MountainManFR-S Brakes, Suspension, Chassis 4 07-02-2013 07:06 PM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
